mini is my ride wrote:
All I know is I want a 1275 modified with a top speed of at least 130 and is able to beat most street cars off line (can I beat a skyline or a rice burner??)
Oh and I have a budget of 3 grand (excludes the buying of the 1275)
Yes you can
I spent about $2500-$3000 (inc gearbox) on my last motor and it might not out run a skyline (with its current diff, 3.2:1), but It does put up a freaken good fight... and its totally happy in traffic.
Seeing as how you've mentioned Rice burners,, I'm going to ASSume that you are talking Km/h? No worries, no worries at all.
This is a moke I did at the start of the year
Now there is absolutely nothing flash about this engine. Its at 1293 with a little more than 10:1 compression. There has been
NO performance modifications done to this motor, its just been blue printed, not even balanced. This one will not burn off WRX's but it goes hard.
EDIT--->
AND ITS IN A MOKE... ie. SAME WIND RESISTANCE AS A HOUSE
Sorry if you misunderstood myself or the doc, but there is nothing reeeaaly wrong with the 731,,, its just that there are much better cams about now days. In a 1275 it doesn't come on until 1500 rpm and there isn't a huge top end advantage.
The problem with running a cam like a kent 286 (the one mentioned by 74snail) is that it doesn't come on the cam till about 2500 in a 1275... which sounds ok in theory, but in practice it can be a pain in the arse in traffic,,, having said that, unlike the 643 or 544 (same grind different oil pump), which are also rally cams that come on at 2500, the kent one isn't as unbearable when its off the cam, you can still drive it easy enough....
