It is currently Mon Jul 21, 2025 4:41 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Oct 06, 2009 6:37 pm
The problem with getting the Timken thrust bearings is they were the original flat type, made for the M1100, 850, Cooper and early S which all used a coil spring clutch diaphragm.
From 1965 on (when diaphragm clutches standardized) no Mini was fitted with these.
The whole world thinks they are superseded by the later (crappy) one, if they even know this bearing existed.
So big demand would not be there.
PostPosted: Tue Oct 06, 2009 9:51 pm
do a search under surplus bearings in Aust. There are a few companies that have some stock of the timken brgs. The other ones that I sourced from them were a R&M part No GR 5/8 B . These are Ransom and Marles made in england good pommy stuff, as good as timken.
I think there may be a few left,I did not buy them all when I got the old style bronze caged RHP gear box bearings from a couple of these companies.
Another company to try is AWB bearings. The branch in adelaide is sourcing me some NTN brgs that are similar to the timken,but 16mm bore.
www.minisprintgt.com
PostPosted: Tue Oct 06, 2009 11:08 pm
If anyone is going to buy up some stock I will take up to 4 if you need to save on freight
David L
PostPosted: Wed Oct 07, 2009 10:30 am
CBC still had a timken one :D
$30 yay
PostPosted: Mon Dec 14, 2009 11:53 am
Looks like I need one now and I will need one for the engine build. Just called CBC here in sydney and they have a number of the 3w5-8 and I correct with these dimentions we need 15.78 Inside Diameter 40.14 Outside Dia and 17.25 wide..CHeers
PostPosted: Mon Dec 14, 2009 6:15 pm
If they've got em, grab em... :wink:
I bought one a while ago just in case, but my current RHP 7W5/8 one hasn't carked it yet. :lol:
PostPosted: Mon Dec 14, 2009 7:25 pm
we'll just had a look and luckly its not the bearing but the Slave rod and piston all the way out..so possibly the clip gave up so at least I can get one of these tomorrow and put it back together again. But I still need one of the bearings for the van and one also for justin
PostPosted: Mon Dec 14, 2009 7:30 pm
Mods rock!
Something else to look out for. I've found on the new AP diaphrames that the thrust plate is now soft :( :( They used to be hardend. I have been swaping the old thrust plate for the new ones.
It seems a bit sad that some of the replacement mini parts are now so cheap (in quality) and there seems to be little alturnative in regards to off the shelf replacements. :(
PostPosted: Mon Dec 14, 2009 7:33 pm
Mods rock!
More info?????
Sounds like the arm is US.....?
PostPosted: Mon Dec 14, 2009 7:38 pm
have had the clutch almost to the floor for a while and have swaped a half dodgy can master with no luck. Wife was dropping our boy off at daycare this morning and had no clutch. we have been hearing a sound when the clutch was engaged so I thought it the bearing had gone. But opening the bonnet I found the piston out of the slave. Clutch arm is/was a new old stock and not bent at all
PostPosted: Mon Dec 14, 2009 7:42 pm
Mods rock!
OK if the arm (even though it's new it might be worth checking the ball on the end hasn't broken off) is OK then yes I'd be looking at the release bearing and the thrust plate on the clutch diaphram.
A bit of a pain when it's the wife trying to do her daily errands and this happens....we can all live without......wifes? :lol: :lol:
PostPosted: Mon Dec 14, 2009 8:12 pm
yer will be checking the arm out and possibly the bearing but I have a feeling the slave was the issue from the start now...we'll see
PostPosted: Mon Dec 14, 2009 8:14 pm
We had probs with that (nearly new) slave last time, and I put a new seal in it..
PostPosted: Mon Dec 14, 2009 8:17 pm
is their any size difference between the 3w5-8 & RHP 7W5/8
PostPosted: Mon Dec 14, 2009 8:19 pm
the 3W5/8 is bigger diameter. And flat face.
Users browsing this forum: 1071 S and 69 guests
