It is currently Thu Aug 14, 2025 7:44 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 110, 111, 112, 113, 114, 115, 116 ... 568  Next
PostPosted: Sat Jan 02, 2010 6:21 pm
:D I found a small tin with annoyingly hard to source little nuts and bolts that I have been looking for, for about a week :!: :D
PostPosted: Sat Jan 02, 2010 6:23 pm
The TIG
I did some more fabrication on the Mini hauling trailer I'm building.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Sat Jan 02, 2010 8:32 pm
Finished putting my interior back in after fitting some underlay under the carpet ,amazing what you find when you strip them out, a few drilled holes that weren't plugged and also the guides that bolt over the handbrake cables weren't there either , all good now though.
Colin
PostPosted: Sat Jan 02, 2010 9:02 pm
Gave the "Snail" a quick service, I found I still hate my McNaught grease gun, given the amount of use the car get's the oil's still a good color.
I,m all ready for the Re-Con Run tomorrow ! :)
Any one else coming ?
PostPosted: Sun Jan 03, 2010 8:05 am
Worked on the gearbox,
mainshaft complete and in place, laygear endfloat checked at 0.002" hope not too tight .
PostPosted: Sun Jan 03, 2010 8:48 pm
Finished my dash.
PostPosted: Sun Jan 03, 2010 8:50 pm
1.
Welded a patch in Lillee's Mini K tunnel where someone had butchered it bad for a rodchange.
2.
Hung the new 1412 stroker motor on the engine stand, drained the fresh clean KMX oil out and threw it all away before pulling the reco rodchange box off it... d'oh!! :lol:
The drain tray had a bit of crap in it... :cry:
Ah well KMX is cheap.
PostPosted: Sun Jan 03, 2010 8:53 pm
chazg wrote:
Finished my dash.
Very very tastefull 8) ...... I'm impressed :)
PostPosted: Sun Jan 03, 2010 10:02 pm
Finished stripping bits out of the engine bay and started stripping paint off the doors and front wings. Doors are pretty much rust free, drivers side front wing has a couple of small patches of rust and more than a few dings. I've beaten a few flat and lessened a few others.. Added a few more things to the seemingly unending parts list.. sigh..... :roll:
PostPosted: Mon Jan 04, 2010 4:10 pm
30 mins work and I'm ready to begin the subframe mount solid conversion.
Now I wonder how many hou....I mean da...I'll stick with weeks, this will take me.
PostPosted: Mon Jan 04, 2010 4:25 pm
chazg wrote:
Given the amount of times it has been have asked for people
to post pictures of their dashes......What about starting a thread just for
dash pictures?
PostPosted: Mon Jan 04, 2010 6:24 pm
I got the brakes working on the Cooper S today. :D :D :D
They have not worked for about 13 years, the master cylinder was leaking onto the floor.
It was not a seal as I would have expected.
The circlip on the bottom of the cylinder was not there at all! :shock: I assume it rusted away! Normally the circlip will still be on the shaft of the pushrod but it was not there at all.
I guess I just swept it up with all the other dirt on the floor a long time ago.
So I just honed the cylinder and refitted the old seals till I get around the doing the whole job properly. :wink: (I just wanted the brake to work so I can move the car around the yard easier, it is not going anywhere)
PostPosted: Mon Jan 04, 2010 7:49 pm
Refitted handbrake cables
Fitted steering column
Put rear wheels on
Flared the new brake pipe at the T-piece (rear sub frame) and at the prop valve (bulk head)
Fitted fuse box and connected wiring
Modified 3 piece wooden dash to suit, yet to be covered
Fitted new headlight wiring loom to globes
PostPosted: Mon Jan 04, 2010 9:35 pm
Finally updated my gallery!!!!
http://www.ausmini.com/forums/viewtopic ... c&start=60
Dave K.
PostPosted: Mon Jan 04, 2010 10:10 pm
I fitted up the front suspension & diff & disc brakes onto my hillclimb special,,, started making up all the brake pipes too
have a gork here--->
http://www.ausmini.com/forums/viewtopic.php?t=60008
so,,, well,,, i actually did something :-)
Users browsing this forum: No registered users and 200 guests
