It is currently Sat Aug 16, 2025 7:14 am
PostPosted: Tue Jan 05, 2010 9:35 am
This is the body no on the radiator cowl . . .
Number in radiator cowl ...
021X2S1M09 25827
Number behind brake master cylinder in firewall...
13027
M2
21
Thanks for any help given . . .
Cheers Scott
PostPosted: Tue Jan 05, 2010 12:31 pm
Rover Cooper
is that the silver Clubbie
PostPosted: Tue Jan 05, 2010 12:40 pm
Wait until morris 1100 comes on. But those behind the master cylinders is a base model mini clubman (mini 1100). the radiator shroud should be yg2s6.
that radiator shroud is from a leyland mini (i think)(m1100 will be able to decifer this)
So to me they do not add up/ ie not from the same car.
cheers Brenton
double post. oops
PostPosted: Tue Jan 05, 2010 1:05 pm
yes it is Davo . . .
It is a base model 1977 Leyland Mini.
PostPosted: Tue Jan 05, 2010 2:45 pm
that may be the correct m/cylinder number for a 77 also not sure. see what morris 1100 reckons
PostPosted: Tue Jan 05, 2010 3:12 pm
Mods rock!
It's a base model 998, with emission control. Nothing special.
PostPosted: Tue Jan 05, 2010 4:05 pm
021X2S1M09 25827
13027
M2
21
Cheers Scott
Leyland Mini. Early 1977. I don't now how early,
From my numbers I have 239** being 11/76 and 268** being 6/77 and that number is in between them. (I have big gaps in my numbers. :lol: )
PostPosted: Tue Jan 05, 2010 5:11 pm
021X2S1M09 25827
13027
M2
21
Cheers Scott
From my numbers I have 239** being 11/76 and 268** being 6/77 and that number is in between them. (I have big gaps between my butt cheeks. :lol: )
PostPosted: Tue Jan 05, 2010 5:32 pm
Hey Morris so the number behind the master cylinder didnt change from 71-77? ( probably 78 )
The gear extention tunnel changed so shouldnt they have come up with a new body style number?
i would have thought these would have changed as the models changed.
Im curiose?
PostPosted: Tue Jan 05, 2010 5:46 pm
Im curiose?
The number changes only happened when there was a signifigant model change. They didn't change the number in 67 when they added channels to the floorpans, they didn't change the numbers when they change the wipers and scuttle panel. So why change it in the 70s for a running change to one panel?
They probably should have changed the numbers when they dropped the Clubman name but there was no great changes to the bodies so why bother. :lol:
PostPosted: Tue Jan 05, 2010 5:53 pm
OK got it..
I learnt something new
Thanks Morris
PostPosted: Wed Jan 06, 2010 12:09 am
:D Thanks for your help people, much appreciated :!:
:P Except you Lil-ute . . . your a "tool" as always, not very useful but still a "tool" :!: :lol: :lol: :lol:
PostPosted: Sat Jan 09, 2010 4:32 pm
Rover Cooper
SCOTT As a Mini mechanic you should know by now that some tools need special modifications to adapt to a special task on a Mini, so why don't we suggest a special modification that will make LIL UTE more useable :wink:
Users browsing this forum: Bing [Bot] and 262 guests
