It is currently Mon Aug 11, 2025 8:26 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 118, 119, 120, 121, 122, 123, 124 ... 568  Next
PostPosted: Tue Jan 26, 2010 7:58 am
pulled the steering column out and dissasembled it.
PostPosted: Tue Jan 26, 2010 9:41 am
Absolutely bloody nothing since the 18 December when me moved :evil:
Too busy painting painting painting - fixing the pool, fixing the ride on mower, mowing lawns, slashing long grass and attending to Her-in-doors AAAAAAAHHHHHHHHHHHHHHHHHH
David L
PostPosted: Tue Jan 26, 2010 10:30 am
Affixed an Australian flag.
PostPosted: Tue Jan 26, 2010 11:01 am
Hmmm , seachanges are relaxing aren't they :lol: :lol: :lol:
Hang in there , I'm sure there'll be some mini time coming up soon .
PostPosted: Tue Jan 26, 2010 11:32 am
Pulled the freshly rebuilt rodchange box off the 1412 stroker. The internals (including new 1275GT 1st motion shaft and cluster gear) are going into a Mk2 S remote casing, so it and the 1412 will drop straight into my `wasaMatic'. :P
PostPosted: Tue Jan 26, 2010 1:09 pm
Actually did this yesterday but I spent the afternoon block sanding putty on the body, doors and boot, then applied another coat. A couple more with some sanding and then she's off to be painted on Sunday (all going well).
PostPosted: Tue Jan 26, 2010 2:27 pm
Starting work on a trailer to drag home more Mini tradgedys, scored a 19 ft caravan for nix so its going to the tip to have the body rolled off and im taking home whats left :D
PostPosted: Tue Jan 26, 2010 5:03 pm
Had a new alternator installed and an electric dizzy :D
PostPosted: Tue Jan 26, 2010 10:02 pm
Test drove the Moke to the beach and back! then gave it a good seeing to!!! lol
All was good!
PostPosted: Tue Jan 26, 2010 10:08 pm
Tomboss Breweros
I took out the passenger seat so i could fit my motorbike in 8)
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Jan 26, 2010 11:26 pm
More blue spray putty, going to be hot the next couple of days so I'll stick her out in the sun to bake it on, then the final block sand before primer and paint on Sunday.
PostPosted: Wed Jan 27, 2010 2:25 am
made sure the battery's been put on charge.. back in Aus on Sunday! :D Can't wait to drive it again!
tim
PostPosted: Wed Jan 27, 2010 4:09 pm
Finished painting m radiator shroud ready for new radiator
It might only have half the engine but its got 4 times the handling...............
PostPosted: Wed Jan 27, 2010 7:04 pm
Give Ash some flowers Nick .
Continuing on from what I posted in this thread a couple days ago:
Freshly machined drum. Although once I put them in I think they took them out 1/32" which I specifically asked them NOT to do :roll: I have to pull one of them back off and measure them.
My brand new A+ crank turned up today as well (getting crack tested either tomorrow of Friday). It's very pretty & std/std (never been in a car).
I also polished the top and bottom tanks of my new eBay radiator so it's ready to put in the car soon (photo doesn't really show it's shininess).
PostPosted: Wed Jan 27, 2010 7:11 pm
The best way to machine your drums is let them take out to +1/32" or +1/16" and supply oversize rebonded shoes, radius ground to suit.
If you just machine them out and use stock shoes, they will be 1/2 worn out before they are bedded in to the drum radius. Then, you will run out of adjustment early too.
