It is currently Sun Jul 20, 2025 8:39 am
 Post subject: paint code please
PostPosted: Wed Feb 10, 2010 9:22 pm
anyone have the correct paint code or mix for the white roof for a 1969 mini cooper s
toga party lol
PostPosted: Wed Feb 10, 2010 9:27 pm
from http://www.elevenhundred.com/colours.php
code is 08452
Might help? :?
PostPosted: Wed Feb 10, 2010 10:32 pm
While were talking paint codes, does anyone know the paint code for the light green engine paint? I need to get some to touch up my engine.
And if you look on your compliance plate it should say number/Toga White/number, where the numbers stand for paint maker and factory(Its been a while since i read it)
Simplify and add lightness
PostPosted: Thu Feb 11, 2010 10:02 am
White Knight alpine green in the spray can section of Bunnings :wink:
David L
PostPosted: Thu Feb 11, 2010 2:53 pm
`Cooper S metallic green' from Mini King, about $40 for a 1L tin.
PostPosted: Thu Feb 11, 2010 7:08 pm
How much difference between them two Doc or Wombat, any idea ,
Colin.
PostPosted: Thu Feb 11, 2010 7:44 pm
They are pretty close, I think the Mini King one is closer to original. But both good.
PostPosted: Thu Feb 11, 2010 9:23 pm
The White Knight is actually a slight hammertone finish which is more pronounced out of a spraycan than brush on. I use brush on out of a 1 litre tin for the block but spray painted the smaller bits and pieces - look close and you can tell there is a difference more in 'texture' than colour but still good
David L
PostPosted: Thu Feb 11, 2010 10:31 pm
I've tried both. White night is a little less minty than Mini Kings paint. It's 35 bucks I think for 500 ml, and about half of that will paint the engine and gearbox. It will take two cans of white night to givew the engine a good coat and touch up at about 10 bucks per can. So the cost isn't vastly different.
PostPosted: Fri Feb 12, 2010 2:18 am
While searching colour codes last night i came across this.
http://www.glasurit.com/COLOR/new-color-online/m1frameset.php?language=1
for future reference
PostPosted: Fri Feb 12, 2010 8:43 am
I theeeenk the correct white for 1 69 Cooper S would be Crystal White (11572)
PostPosted: Fri Feb 12, 2010 3:07 pm
Does not work on Australian colours.
PostPosted: Fri Feb 12, 2010 4:53 pm
the white on my 69 S is 1/SNOW WHITE/1
PostPosted: Sat Feb 13, 2010 11:52 am
http://www.ozcooper.com.au/paint_codes.htm
all u need to know
PostPosted: Sat Feb 13, 2010 11:53 am
all u need to know
Users browsing this forum: No registered users and 69 guests
