subwayseth wrote:
It has the "s" guard extensions, spaced type drums & 10x4.5 jelly beans I intend on wrapping in perhaps a falken tyre
Well since it has the "S" guard extensions all that would probably fit on there are "S" type flares. There is an extra wide set available, but they would need extra steel welded onto the extensions for them to fit in the normal way, ie small clips that hold both flare and trim to it. The majority of the other flairs look to screw onto the side body work. The size of tyre you are looking at should have no problem fitting within the lines made by the standard "S" guards, if you went wider it may look a little strange. But that's only my opinion, it's your car do what you want.
