TheMiniMan wrote:
i find it difficult to believe that """slightly""" worn shafts would interfere with or produce any (much) drama with engine revs up where you`re talking about,,, with throttle open some-what, the shafts wear plays less havok than on idle or very slight throttle
but still if you want them "Perfect" then by all means don`t let me stop you spending time & money on them,,, i like them all nice & lovely before i tune them too
you live up north-ish somewhere don`t you Phil ??? The guys at Carb-Tech in Kipparing are legend carb repair people , Ian Stewart (Navigator for one of the fastest Aussie rally drivers) works there & is VERY VERY good carb specialist, i would suggest he is one of the Very best in the Brisbane area.
Yes I realise probably not related to my original problem but while off the car thought i might get them checked out.
I had been having a little trouble with the idle, namely it would be high and then slow down, but with the needles I had I think I was having to have a really rich idle to get correct mixture at speed.
I guess I might only need new spindles, the body might not need rebushing.
I'm in Wollongong actually but work in Sydney.
I did discover a manifold nut was loose/damaged so replaced it and it's nice and tight now, that may have been part of the original problem.
The needles I'm sure were not suited, I did a bit of experimenting and as I increased the mixture the problem moved further up the rev range.
I have some new needles now which should be richer at higher revs.
Trying to check my floats now (see new post)
Have checked fuel flow rate. It pumped 140mls in 15 secs so 560ml/minute. Someone said should be 1 litre per minute so maybe this is another issue?
