It is currently Sun Aug 10, 2025 9:39 pm
PostPosted: Thu Apr 01, 2010 5:16 pm
I've got an 850 engine (many thanks for Remickz!!) and interested in the crank shaft. It appears to have had a fair bit of wedging done to it.
Is it a factory thing, or has thing engine had been ballanced in a previous life?
PostPosted: Thu Apr 01, 2010 5:24 pm
Good luck, i will be keen to find out if there is anything interesting about the engine :)
PostPosted: Thu Apr 01, 2010 5:26 pm
The fact that the box that you gave me with it was a 1128 and the diff housing an 850 magic wand (not the 4spd synchro magic wand type) makes it quite interesting, if it was infact one whole power plant at one point.
PostPosted: Thu Apr 01, 2010 5:59 pm
I have a 850 crank here that sounds just like yours, with what looks like wedging on some of the webs.
I'm not sure, but from the theories I've heard the one that made most sense to me was that it was actually some sort of rudimentary balancing done at the factory to correct gross imbalance.
Like I said not really 100% on that...
Jacob
PostPosted: Thu Apr 01, 2010 6:00 pm
From memory 850 cranks had more pronounced counterweights, but this shape was in the forging.
If there is evidence of bits machined off flat to make the webs triangular (as in a wedged 1275 crank) then yeah it's been wedged by somebody since manufacture.
Factory balancing was a quick bump against a big grinding wheel, usually on 1 web only.
PostPosted: Thu Apr 01, 2010 6:11 pm
So I take it that this wedging is very much NOT factory?
PostPosted: Thu Apr 01, 2010 6:33 pm
THAT is the factory balancing job.
THIS is wedging-
PostPosted: Thu Apr 01, 2010 6:39 pm
Ahhh ok. I wasn't sure on how far the extent of wedging went.
PostPosted: Thu Apr 01, 2010 6:45 pm
I wedged it on my trusty Hafco HM30 mill/drill at home, took me nearly 6 friggin hours! :lol:
Then I cleaned it up on the belt linisher at work, and GR balanced it.
Looks pretty good for a $50 barn find crank don't it.
It's a 12G1505 that's now been stroked 3.0mm (to 84.33) and bearings are still std/std.
Users browsing this forum: 63lcn and 189 guests
