It is currently Sat Aug 02, 2025 12:25 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Mon Apr 12, 2010 9:48 am
phreak97 wrote:
taper rollers push outwards from the middle, I dont see them meeting in the middle being a huge issue so long as the rollers are seated in the correct position on their races (no slack) and not being crushed (not overtightened).
ball bearings are a different story, they need their races to be held in place from both sides.
in any case, the nut is designed so that if the split pin breaks it will just overtighten itself (left hand thread on the left side), but the split pin is just to stop tightening from vibration combined with the influence of the direction the wheel is turning, theres no torsional load on it.. if it breaks you already had problems.
I'm with you (as an experienced fitter/onetime VW/Formula Vee mechanic). I'm fitting 2 rear Unipart Timken kits to mine today,we'll see how tight they are when assembled. I won't be putting any shims in... I'll back the nut off if needed.
PostPosted: Mon Apr 12, 2010 8:48 pm
Tomboss Breweros
Well i fitted them and they were too tight for my liking before the nut was anywhere near torque so i backed it up and pinned it. Nice and quiet now :D
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Apr 12, 2010 10:32 pm
This space for rent
Interestingly (and probably not surprisingly) now that my bearings have done a few hundred miles and are run in, they needed the shims taken out... :roll:
All torqued up and they feel perfect now..
PostPosted: Mon Apr 12, 2010 10:48 pm
lol, that kindof confirms what I was saying.. I guess they just need readjusting after they've worn in.
The fleet:
1949 Fiat Topolino
1965 Morris 1100
1966 Mini Van (project)
19?? Morris 1500 (for sale)
1979 Chrysler Regal
1990 FSM Niki
PostPosted: Mon Apr 12, 2010 10:50 pm
This space for rent
:D
PostPosted: Tue Apr 13, 2010 9:46 am
very interesting thread this one - I've learnt a lot, thank you :)
