It is currently Thu Jul 03, 2025 1:01 pm
 Post subject: rear wheel hub
PostPosted: Mon May 17, 2010 4:25 pm
gday everyone!
so i spent 3 hrs yesterday trying to remove the large nut (im not sure what it is called) holding the wheel hub to the rear axle! in the end, i had to cut the nut in half :evil:!!!!!!
so i was wondering if anyone knew what this nut was called, and if anyone knows where i can get a spare from?? i had a quick look on the minisport website, and only found them for disk brakes
cheers!!!
PostPosted: Mon May 17, 2010 4:33 pm
This space for rent
Which side was it, driver's or passenger's? The passenger side is a left-hand thread, so if you were trying to undo it anti-clockwise, you were actually tightening it ;)
It's called a 'castellated nut', but you're best off trying to get one from a Mini specialist, especially if it's the passenger-side one. If you do find one at a bolt supply place, often the slots for the split pin are too shallow.
Is one side left hand thread?
Edit: to slow...
PostPosted: Mon May 17, 2010 6:09 pm
I'm sure every mini specialist will have one lying around. Phone them up and talk to them as its not something you would commonly list on the net.
Users browsing this forum: Bing [Bot] and 81 guests
