It is currently Mon Aug 04, 2025 5:28 pm
 Post subject: van hood lining
PostPosted: Sat Jun 05, 2010 12:25 pm
Hi
Has anyone put hood lining in the back of a van ???
how did you do it ??
any photos ??
would be appreciated.
Thanks
Mark
PostPosted: Sat Jun 05, 2010 2:19 pm
Don't have any photos but I removed the original lining, got some black carpet from Clark Rubber and glued it straight to the roof. Definitely does the job for me and means not needeing to put in hood bows or needing to stretch the material to fit.
One idea anyway.
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
PostPosted: Sat Jun 05, 2010 2:33 pm
did the same with mine used spray contact cuts down the noise and its warmer inside :D :D
PostPosted: Sat Jun 05, 2010 3:24 pm
frednutz&co wrote:
did the same with mine used spray contact cuts down the noise and its warner inside :D :D
warmer.. inside...
minis need to be hotter in summer? :shock:
You're so square
Baby I don't care
PostPosted: Sat Jun 05, 2010 3:41 pm
Mods rock!
adamstuart wrote:
warmer.. inside...
Well, both those guys are wetbacks....... :wink: :lol:
PostPosted: Sat Jun 05, 2010 3:49 pm
again glued some carpet to the roof. did all round the sides as well. no pics as i've just ripped it out for a rebuild
1962 850,Frog
PostPosted: Sat Jun 05, 2010 3:55 pm
Another tip for spray glue is to mix products like "kwik grip" down with thinners and spray like spray paint. Use a primer gun, and cover large areas quickly with this method. I think for best results, spray two coats with a few minutes flash of time between coats.
Sticks like sh!t to a blanket! :lol:
mooo, I'm a pig!
PostPosted: Sat Jun 05, 2010 4:20 pm
I did min a bit differently.
I got an 850 (I think they came in the 850's) headlining frame and extended it in the middle. I then glued some other stuff to it and covered it. Came up pretty cool. Some might say its a bit OTT but I like it.
This is not finished in this pic and lines up beter now and fits better in the corners.
PostPosted: Sat Jun 05, 2010 6:25 pm
Or you could try this... www.selleys.com.au/Selleys-Kwik-Grip-Spray
It is new! It may be easier on small jobs but your way would be better on large jobs. :D
PostPosted: Sat Jun 05, 2010 9:29 pm
we I have this to enjoy thanks to the PO. You will see the bears foot prints on the wall but this is also the case on the roof :roll: but it may shut the drone out while driving. Yep its all stuck on by slapped on Kwik Grip so its stays on for the time being as its going to be a rite pain to get off
You do wonder what some people where thinking don't you
PostPosted: Sun Jun 06, 2010 9:52 pm
dang, maybe i should put some paint on min :roll: ....im eventually going to do a shag plie carpet on the floor just for that 70's feeling :lol:
