It is currently Mon Jul 21, 2025 1:44 pm
 Post subject: stuck wheel bearing nut
PostPosted: Wed Jun 09, 2010 2:03 pm
Problem:i removed the rear subframe on saturday & started stripping it down to be painted, rebushed, ect. got all the parts off with exception of the right side bearing nut, it wont budge even though it's packed full of grease, got any ideas? also the dampers are still in due to the top of them corroding but i'll see if giving them a soak in lube will loosen them
PostPosted: Wed Jun 09, 2010 2:07 pm
Are you turning it the correct way?
Though I think the right side is normal thread direction...
PostPosted: Wed Jun 09, 2010 2:10 pm
checked thread direction, not that
PostPosted: Wed Jun 09, 2010 2:11 pm
Its the rear left thats backwards.
But if the frame is upside or you turned it round then youll have to work out which is which.
Simplify and add lightness
PostPosted: Wed Jun 09, 2010 2:15 pm
nope, checked i was going correct way to the thread
PostPosted: Wed Jun 09, 2010 4:42 pm
I just had a couple of dramas removing one off one of my front wheel hubs. Spanners and a vice could not budge it, but my 3/4 rattle gun smacked it!
Could a rattle gun be an option?
mooo, I'm a pig!
PostPosted: Wed Jun 09, 2010 5:16 pm
yea that could be as i was planning on getting one someday...i guess sooner than later :)
PostPosted: Wed Jun 09, 2010 5:20 pm
It's not how big your tool is, big boy. It's what you do with it :wink:
PostPosted: Wed Jun 09, 2010 5:27 pm
well i had one big mother of a shifter on it & a 2.5m long pipe on the end & still no workie :roll:
PostPosted: Wed Jun 09, 2010 5:35 pm
For some obscure reason 1stmotion, your avatar picture has me VERY curious about you. :lol:
Hopefully subway, the hammer action of the rattle gun can help. At work I also have an impact driver for sockets. Looks like an awkward ratchet, but what you do is put socket on the driver, place on nut, then belt it with a hammer. It multiplies the force in a turning motion, and jars the nut at the same time.
Cool tool!
mooo, I'm a pig!
PostPosted: Wed Jun 09, 2010 5:37 pm
You could always fit a ring spanner to the nut and then hit it with a hammer or a block of wood. :wink:
PostPosted: Wed Jun 09, 2010 5:38 pm
Cool tool!
great idea, i have one only its for a screw driver type attachment but maybe able to use a socket too :)
PostPosted: Wed Jun 09, 2010 5:52 pm
Cool tool!
give it a go, but mine is actually designed for 1/2" sockets. Let us know if it works.
mooo, I'm a pig!
PostPosted: Wed Jun 09, 2010 5:57 pm
Mods rock!
Try tightening it a little first.
Any chance of a pic?
PostPosted: Wed Jun 09, 2010 6:01 pm
i'll go grab one now
Users browsing this forum: Bing [Bot] and 87 guests
