It is currently Fri Jul 11, 2025 2:02 am
 Post subject: EDIS Spark Plug Leads
PostPosted: Mon Jun 21, 2010 6:34 pm
Hi all that have fitted EDIS to their cars. What spark plug leads did you use? I know the length depends upon where you mount the coil pack, but I have some latitude in mounting this somewhere around the right side of the cylinder head or just in front of it on the right side (below #4 spark plug).
Trolling the Internet some say that Ford KA or Fiesta leads are a good fit.
Jim.
PostPosted: Mon Jun 21, 2010 10:07 pm
you can buy heaps of kits via the uk :)
search http://www.turbominis.co.uk/
PostPosted: Mon Jun 21, 2010 10:09 pm
I think someone mentioned they just shoved their old mini leads onto the coil. I personally just got the leads that came with the coil but i haven't fitted it yet.
Another option is make your own, this isn't that hard to do really and would be a lot cheaper then buying a set of ford KA or fiesta leads, as they will set you back around $100.
I'm not sure if the usual repco/autobahn etc sell lengths of leads and the necessary ends though. It's worth looking into.
PostPosted: Mon Jun 21, 2010 10:19 pm
you can get some made as well.
yellow pages!
i got some made for my mini with standard ends & one a bit longer as i run aircon.
was $50 or so. :)
PostPosted: Mon Jun 21, 2010 10:20 pm
Thanks for that. The coil towers on the coil pack take an unusual style lead connection that I've not seen before. If I could get the correct ends, I would modify a standard set of leads other wise I can get Ford KA leads for ~ $70, and if required shorten them.
PostPosted: Mon Jun 21, 2010 10:26 pm
yellow pages!
was $50 or so. :)
Will look into this... let your fingers do the walking! 8)
PostPosted: Mon Jun 21, 2010 10:39 pm
pfft - standard leads $5 each from supercrap... same ones I had on my pulsar dizzy
PostPosted: Mon Jun 21, 2010 10:52 pm
So your point is that standard lead ends can be made to fit? :)
PostPosted: Mon Jun 21, 2010 10:58 pm
yeah, I just shoved them on - I think it was 14 months and maybe 10 motorkhanas ago now... no sign of them coming off, and I pressure wash the motor at the car wash
Pristic did that with his, I was going through the pain of trying to find leads and he said he'd just jammed the standard ones on
PostPosted: Tue Jun 22, 2010 9:50 am
Thanks Simon, looks like you have started a trend! :wink: :wink: I'll try the same with mine. From pictures I've seen on the web, It looks like the originals (EDIS) have some sort of locking clip that goes under the large ridge on each post... I'll try your method, until maybe I can find some EDIS clip things. :)
PostPosted: Tue Jun 22, 2010 10:11 am
You can get the EDIS coil pack clips here:
http://www.boostengineering.net/category_s/1.htm
If your tricky you can even remove the clips, terminals and boots off the old mondeo leads and swap them onto another set, but it seems a bit of a waste of time if the standard leads jam on there!
Andrew
PostPosted: Tue Jun 22, 2010 10:18 am
not so much started the trend, just taken it mainstream....
I have the leads with the locking clips that came with my coil pack, I started to take them apart to make new leads, then thought "screw this, I'll do that if pushing the standard ones on doesn't work"
BTW - the coil pack is basically generic, you can use a coil pack off a few different cars, the EDIS is the little black box which is the important part...
PostPosted: Tue Jun 22, 2010 10:23 am
Andrew
Just bought some from them! Thanks for that link. :D
PostPosted: Tue Jun 22, 2010 12:00 pm
Have just come across this "electronic ignition" setup, I'm assuming this so that we don't have cough n splutter issue when driving in the wet?
Might have look into this :-)
Rohan
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Tue Jun 22, 2010 12:07 pm
This concerns me...
EDIS 4 Ignition Leads
Part is Used
Guaranteed Functional.
