It is currently Mon Jul 21, 2025 6:05 am
 Post subject: paintwork.
PostPosted: Thu Jun 24, 2010 6:10 pm
so i filled my mini with bog ect. it was there for like 8 months though. just the bog. i put the primer on. and then sprayed 2 pack on. and then it started eating through the primer ?? and then you could see the bog cracking :S
anyone know why??
Mini Clubman 72 aka Juno 998cc
PostPosted: Thu Jun 24, 2010 6:33 pm
how long whe primer on for before you sprayed top coat? sounds like it wasnt dry
Potato
PostPosted: Thu Jun 24, 2010 6:39 pm
umm. few days. lol
PostPosted: Thu Jun 24, 2010 10:20 pm
was it a 2k primer mixed as a 2K?
mooo, I'm a pig!
PostPosted: Fri Jun 25, 2010 4:12 pm
it may be the 2k eating into the primer. Also, bog is very porous it was probably still wet with prep-sol.
blokeinamoke wrote:
PostPosted: Fri Jun 25, 2010 4:19 pm
Lots of reasons really, like a 1k primer used under 2k paint. The etch primer layered on thick (etch primer really shouldnt be built up).
mooo, I'm a pig!
PostPosted: Fri Jun 25, 2010 5:44 pm
you can't put 2 pack over acrylic products including filler, the proper filler for 2k is double the price as it is more dense, you can put acrylic over 2 pack, sound like you need to strip it again or use a heap of isolater and start again!
2 pack filler+ primer+ paint
2pack filler + primer acrylic top coat but why bother
or acrylic filler + primer + acrylic top coat.
hope this helps
cheers anthony
PostPosted: Wed Jun 30, 2010 10:15 pm
Can i use ordinary (acrylic) primer on fibreglass (full bonnet) or do you need something special.
PeterN
3x Leylands
1x 850
Mildura,
Victoria.
PostPosted: Wed Jun 30, 2010 11:30 pm
you can use acrylic primer provided you key the fibreglass up, best way is to wet and dry then use scotch bright pads and rough it too it's a mat finish.
cheers Anthony
Users browsing this forum: JM1275 and 97 guests
