It is currently Sun Jul 20, 2025 12:56 am
PostPosted: Sat Jun 26, 2010 8:28 am
Ok it started two month or so ago when a mate purchased a little red deluxe, the body is in great shape with next to no rust but the paint in not very good and done in acrylic.
its got S brakes, 1275 ls motor and rod box, twin 1 1/4's, new interior with retrimmed seats, carpets, door trims etc
good little buy at the price he got it for.
so its unreg and he asked if we can take it straight to mine, i say ok drop it over and i will have a look over it for you.
brakes dont work, it does not start, so i got a bit of work to do yeah.......
well after I find around 1/2 kilo of dirt in the float bowls and float seats not shutting off i got it running ok, for now anyway.
but after 5 mins of running it cuts out and there is a bit of smoke from under the engine, smells like electrical smoke................
Bloody fool of a previous owner has run the battery cable over the top of the exhaust pipe which has melted through the plastic of the cable......... DAM FOOL
fix that with a new cable.
So this week I decided to look at the massive amount of camber on the drivers side front wheel and the brakes.
well to my surprise there is only one bush on the caster arm....
fit new bushes, found some play in the ball joints so I thought I would remove the hubs and re-shim them on the bench.
cant undo the ball joints...... eventually get them off and have now fitted 4 new ball joints.
and now for the brakes......
ok small mistake sure anyone could fit the calipers on the wrong side to have the bleed nipple at the bottom of the caliper and not allow the air to bleed out.
swap em over fit new flex lines as they were craking and go to look to bleed the fluid through, wow that fluid looks funny........ the reservoir is all stained RED and ther fluid is so thick.......
the bloody fool has been trying to bleed the brakes with transmission fluid.................
OMG what else am i going to find on this car.
seems like its going to be a long build.
I wonder what other surprises i am going to find.
Grant
100% Pure A Series Turbo
PostPosted: Sat Jun 26, 2010 9:45 am
Sounds like mine :roll:
David L
PostPosted: Sat Jun 26, 2010 10:39 am
It reminds me of that show that used to be on TV called "Bush Mechanics". I would check the tyres as they are probably stuffed full of grass and actually have no air in them! :wink:
PostPosted: Sat Jun 26, 2010 11:28 am
g-Rant
I feel your pain. Most second hand cars are just someone else's problems.
But, I find that the dumbheads who do the dumb crap as you have mentioned are usually to stupid to be "really" dodgy to the point of being sly and deceptive.
You will probably find more goofy type stuff but the mayor stuff should be "fingers crossed" pretty legit..
blokeinamoke wrote:
PostPosted: Sat Jun 26, 2010 4:15 pm
If the brake system has been filled with auto oil you will need to change all the rubbers in the master cylinder and wheel cylinders.
PostPosted: Sat Jun 26, 2010 4:35 pm
ATF ain't oilz, it is actually glycol based. It's closer to brake fluid than motor oil... :lol:
PostPosted: Sat Jun 26, 2010 4:44 pm
It can still stuff the seals in brake systems.
PostPosted: Sat Jun 26, 2010 5:52 pm
Very true. Change the lot and flush the system.
PostPosted: Sun Jun 27, 2010 7:47 pm
You surely couldnt have seen it all untill you have seen...
Yes its Bacon flavoured mayonaise...... :shock:
PostPosted: Sun Jun 27, 2010 7:58 pm
Bacon Jelly Beans
Dicko
PostPosted: Sun Jun 27, 2010 8:15 pm
OMFG... now IIIIIIIIIIIIIVE seen everything........ :shock: :lol:
PostPosted: Sun Jun 27, 2010 8:28 pm
Not Yet....
Bacon Flavoured Envelopes
Gummy Bacon
Bacon Mints
Bacon Lip Balm
and there's even more... http://www.thinkgeek.com/caffeine/all/
I get a lot of my T Shirts from them. Some are quite witty.
Dicko
End of Hijak :shock:
Dicko
PostPosted: Sun Jun 27, 2010 10:51 pm
With rebuilding Hetty I found paper stuffed into places with bog smeared over the top. I think that's the worst thing I've found so far, no wait there was the Woodstock and Cola can pop rivetted to the rear beaver panel to fix a rust hole (actually I thought that was pretty clever). Worst bodge job I've done on her was to fix the sill panels, battery box and boot floor with steel sheets cut from washing machines. :)
PostPosted: Tue Jun 29, 2010 5:26 pm
awesome finds guys, now i have seen everything.
