It is currently Fri Jul 25, 2025 8:01 am
 Post subject: Modifying Pedal Box
PostPosted: Mon Jun 28, 2010 4:00 pm
Hey,
I was just wondering if there was a way i could modify my brake and clutch pedals so that when my accelerator is lower than the other 2 pedals? (if that makes sense?) I want to be able to double clutch a little bit easier. At the moment when im braking the acc. pedal is a fair bit higher than the brake when its fully down so its very awkward to get my heel across.
The reason i double clutch is because sometimes my gear grinds between 3rd and 2nd and when i i give the acc. abit of a hit while changing gear it changes smoothly.
I was thinking of bending the brake and clutch pedals abit so that when the brakes are on full the pedal isnt fully down.
I dont know if this is a stupid question or if will effect anything but i thought id ask before i did it.
Thanks Blake
PostPosted: Mon Jun 28, 2010 4:07 pm
Be careful if you bend them, dont want to weaken it too much..
last thing you want is to snap your brake pedal
You're so square
Baby I don't care
PostPosted: Mon Jun 28, 2010 10:29 pm
Maybe it would be easier/safer to raise the acc. pedal instead???
Might make cruising a little more uncomfortable though...
PostPosted: Mon Jun 28, 2010 10:32 pm
I use the side of my foot on the accelerator pedal....
PostPosted: Mon Jun 28, 2010 10:42 pm
I use my big toe.
You're so square
Baby I don't care
PostPosted: Mon Jun 28, 2010 10:57 pm
adamstuart wrote:
I use my big toe.
when double clutching
PostPosted: Mon Jun 28, 2010 10:59 pm
Yes, i use my big toe.
work that one out :wink:
You're so square
Baby I don't care
 Post subject: Double the clutch
PostPosted: Tue Jun 29, 2010 6:50 am
It sounds like you need to replace the synchros in the gearbox if you are needing to double the clutch. I have never had any problems doubling the clutch in a Mini. Pedals are oK where they are.
"Let us remove your "SHORTS"
PostPosted: Tue Jun 29, 2010 7:28 am
I second the "fix the gearbox, not the pedals philosophy"
KB
PostPosted: Tue Jun 29, 2010 8:44 am
I just adjusted mine (at the carb) so that it was full throttle as close to the floor as possible (I also made an adjustable pedal stop so it had a definite stop point and didn't stretch the cable). I also have aftermarket brake/clutch pedal plates which help as well.
PostPosted: Tue Jun 29, 2010 8:46 am
Its all in the heal-n-toe with a twisted foot... I've seen some amazing footage of nascar drivers double clutching on road tracks
1975 Hairy Lime/White Clubby
 Post subject: Re: Modifying Pedal Box
PostPosted: Tue Jun 29, 2010 4:15 pm
blake12345 wrote:
Hey,
Thanks Blake
as simon said, i use the side of my foot when double clutching. Using your big toe, would make it awfully arse about face i rekon..
I do find that after having owned a few mini's each of the pedals are at different heights and some are more comfortable for driving than others...
 Post subject: Happy birthday
PostPosted: Tue Jun 29, 2010 4:23 pm
Tomboss Breweros
My well adjusted and bled drums give me a good enough brake pedal so this is no problem. I just push the brake more with the ball of my foot then operate the acc with my little toe at the same time :wink:
kimini wrote:
PostPosted: Tue Jun 29, 2010 4:32 pm
blake12345 wrote:
.... At the moment when im braking the acc. pedal is a fair bit higher than the brake when its fully down so its very awkward to get my heel across....
Are your brakes bled well? Your brake pedal might be lower than it should be / needs to be. :wink:
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Tue Jun 29, 2010 11:18 pm
Just get the revs right in the first place and left foot brake. If your synchros are on the way out itd be preferable to pull the engine out and fix everything at once.
Simplify and add lightness
