It is currently Wed Jul 30, 2025 2:00 pm
 Post subject: Plug fouls up - why?
PostPosted: Sat Jul 03, 2010 9:03 am
I have a mini 1100 with 1.5 inch carb and basic extractors.
The number 3 plug fouls up regularly.
Replace the plug and it runs well for several days – Car only does short trips.
Compressions are all even.
Valve clearances and lift are also good.
I have also changed the coil, distributor and leads making no difference.
What can be causing number three to foul up given the compressions are all good?
 Post subject: Re: Plug fouls up - why?
PostPosted: Sat Jul 03, 2010 9:17 am
Mods rock!
Is it oil or carbon fouling?
Could be worn valve guides or ring problem.
PostPosted: Sat Jul 03, 2010 9:24 am
Plug looks wet like oil or fuel.
PostPosted: Sat Jul 03, 2010 10:10 am
Mods rock!
If they look wet (and a bit crunchy) then it is Oil (although have your check / replaced yr leads?).
Your've done a compression test yeah, but have you done this at operating temp and a dry and then wet test? (dry is just that and for a wet test squirt a little bit of oil in to each cylinder then test again).
PostPosted: Sat Jul 03, 2010 10:28 pm
My 998 mini has had a similar problem but fouls number two plug. It has the same carby and exhaust set up as yours and also only does short trips. I have found that if I keep the fuel fresh and have at least a quarter of a tank of fuel I don't have the fouling problem. Having said that it will probably stuff up tomorrow.
Why don't people believe me when I say Arianca Tan will make a come back.
Users browsing this forum: No registered users and 65 guests
