It is currently Sun Aug 03, 2025 6:44 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 166, 167, 168, 169, 170, 171, 172 ... 568  Next
PostPosted: Mon Jul 12, 2010 9:32 pm
jb007 wrote:
jb007 wrote:
jb007 wrote:
Nearly completed my TechEdge 2Y Wideband O2 sensor kit, only one more connector to solder. Why do I leave the crappy jobs to last? :?
Next step build the MegaSquirt kit. :D
Well I finally finished cable, now I know why TechEdge offer an completed cable on their web site! :P
Did preliminary power tests... all OK. Inserted CPU and support chips no talky to netbook via USB to RS-232.:(
Found that no name USB to RS-232 converter was a piece of s#%t. Purchase new brand name converter, connected and away it went.
Moral of the story is don't buy no-name USB to serial converters of Flea Bay. :evil:
Now onwards to building the MegaSquirt. :D
Today was MegaSquirt build day. It's up and running and have been able to flash firmware.8) Tomorrow will finish it off. :)
cool :) thanks for the lead on the O2 sensor kit :)
PostPosted: Mon Jul 12, 2010 9:42 pm
Cool, are you going to build up one? 8)
PostPosted: Mon Jul 12, 2010 10:36 pm
Pulled the engine out, now it really feels like I am making progress.
Was really easy too. :D
PostPosted: Tue Jul 13, 2010 4:23 pm
Spent a few hours with Greig at Miniclassic. Twin carbies have a bad lean spot at low revs that is really annoying. Pulled apart carbies, centre jets, set the jet height, heavier oil in the dash pots, blah blah blah.
Job done, drove home via OPH and still not exactly right. Greig suggested linish the needles. Spent the afternoon taking 0.003" off both needles approx 10 mm from the top - now a million times better but still needs another small amount taken off. :D :D :D
Oh and he adjusted the brakes - brilliant. :D
Dave K.
PostPosted: Tue Jul 13, 2010 9:05 pm
Finished installing all parts in MegaSquirt. Powers up OK, will try to test further tomorrow, (bit difficult as I don't have an Oscilloscope at the moment). :roll:
PostPosted: Tue Jul 13, 2010 11:00 pm
Replaced the Tie rod end bushes, cleaned out the brake dust and then drove the Hetty monster around for a bit, did a little bit more exploring of the rev range. Me likey..
PostPosted: Tue Jul 13, 2010 11:24 pm
pulled over twice to put in the piston damper... :cry: really need to fix that...
Cheers, Ben
- 1974 Leyland Mini S
PostPosted: Wed Jul 14, 2010 10:04 am
NAV-MAN
I found that 1 loop of plumbers tape was good enough to stop mine from coming undone. That was until I replaced it. no for it need now
PostPosted: Wed Jul 14, 2010 11:11 am
Got sick of not having an oscilloscope, so just ordered one from fleabay (local Melbourne dealer). Now I can get on with not only this project, but all the other projects that are just lying around. :D
PostPosted: Thu Jul 15, 2010 4:46 pm
Resident Haemorrhoid
Much needed Oil change done :D
removed old exhaust :D
Fitted new exhaust rc40 and LCB and new inlet manifold 8) :D :D
Many thanks to John From MINI KING for doing a great price 8) :D :D :D :D :D
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Jul 17, 2010 5:55 pm
Replaced the primary gear oil seal on my Cooper S in preparation for the MCC outing to Bowral next weekend. Put the car all back together, bled the brakes and started the car for the 1st time in a bout 6 weeks. Have to take it for a blast tommorrow to make sure its all back together OK.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jul 17, 2010 6:07 pm
left home at 8.00am
and went for a loooong drive to gelong,torqueyand a lot of places and finished at anakie and then home to ftgand just got home :D :D :D :D :D :D
PostPosted: Sat Jul 17, 2010 9:06 pm
you don't need an oscilloscope to make your megajolt work - you just wanted an excuse to buy one :P got a link?
one of the places I work at have a lovely little 2 channel 12v tektronix I borrow :D
and yes, very likely to buy a o2 meter kit, looks like a good thing for the price
PostPosted: Sat Jul 17, 2010 9:28 pm
Made a water recovery system out of a 1lt Wax and Grease remover tin. Bought the new radiator cap to go with it. Installing heater core to add to the cooling system tomorrow in preparation for some summer driving down to the South West later on in the year..
PostPosted: Sat Jul 17, 2010 9:31 pm
You've caught me out! No really I muck around with a lot of micro controllers, field programable grid arrays (FPGA's) and my latest interest is in a product from XMOS http://www.xmos.com/. I used to have access to Tektronics CRO's from work, and in later years I have begged from a friend. Thing is when you need one you don't have it to hand so I just bit the bullet so to speak and bought this one: Rigol DS1052E http://www.rigolna.com/products_ds1000d.aspx ($500)
Don't tell everyone, but two minutes later I updated/hacked it too the model above 100MHz; see http://www.youtube.com/watch?v=LnhXfVYWYXE 8) (Saved about $350!) My brother was so impressed with the unit, he bought one also.
The O2 meter is great, and will help me tune the MegaSquirt, as it will output the wideband info to the MS, which will help in the tunning of the volumetric efficiency (VE) tables.
I was wondering if anyone would be interested in my attempt to convert my car to TBI, maybe a progress report and pictures etc in a new thread:?:
I have gathered most of the things, just waiting for the injector adapter and other bits to be delivered this Monday. :roll:
So I guess you'd could call me a 52 year old geek! :oops:
Users browsing this forum: Bing [Bot] and 93 guests
