It is currently Thu Aug 07, 2025 11:08 am
PostPosted: Fri Jul 16, 2010 5:25 pm
Do you earth Aluminium radiators?
PostPosted: Fri Jul 16, 2010 5:38 pm
bit of wire from one of the screws in the shroud to the body... ?
PostPosted: Fri Jul 16, 2010 5:51 pm
Folklore says leave it insulated on the rubber grommets. Otherwise you will create a ground loop + electrolyte = corrosion.
PostPosted: Fri Jul 16, 2010 5:55 pm
Mods rock!
If you must run an aluminium radiator (and invite all the long term problems that come with it) Insulate it, If you cannot do that for certain, then soildly earth it. Or your best bet for trouble free motoring is to put a copper one in.
PostPosted: Fri Jul 16, 2010 9:40 pm
and stick a zinc annode in the radiator some where. that will get eaten away first before your radiator.
Personally I would go with good copper one, unless weight is a big issue for a race car.[still use copper and go on a diet :D ]
www.minisprintgt.com
PostPosted: Fri Jul 16, 2010 10:16 pm
:oops:
PostPosted: Fri Jul 16, 2010 10:19 pm
Hows this go with an alloy block as well as the alloy rad?
Users browsing this forum: Barkfast and 84 guests
