It is currently Sun Jul 27, 2025 10:34 pm
PostPosted: Tue Jul 20, 2010 8:01 pm
ok, some help please
my dad bought a fan belt at auto barn for a leyland mini, i assume the same size? looks thicker a bit? code is Bosh 11A0815
his mini is a Rover Mini
the Bosh belt did look thicker when i put it on & i'm sure i tensioned it right.
so he has been driving the car and the radiator. is boiling i can hear it bubbling inside.
i watched him today and he poured some coolant in half a bottle 200 mill with out mixing it just topped it, had coolant in it before, you think thats it?
or the fan belt?
PostPosted: Tue Jul 20, 2010 8:15 pm
Rover Cooper
You didn't put it on back the front did you :cry: :cry: :cry:
Sorry mate, its my warped mind.. :twisted: :twisted: :twisted:
Have a listen to the water pump while the engine is running, screwdriver held up to ear, see of something has let go inside, sounds a bit strange if you just changed the Fan belt...try and put the old one back on again and see if its the same..???? :roll: :roll:
PostPosted: Tue Jul 20, 2010 8:19 pm
haha
yes well i did the same thing to my car and it's been happy days.
just seems odd, i replaced his and it's doing this.
if they are to loose can that cause a problem? i made it tight and i cant hear any belt slip, maybe to tight.
will check all this in the morning for him.
PostPosted: Tue Jul 20, 2010 8:40 pm
Did you take the fan off at all?
PostPosted: Tue Jul 20, 2010 8:43 pm
No and it's facing the correct way ;)
