It is currently Thu Aug 14, 2025 8:11 am
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri Jul 30, 2010 4:54 pm
Saw a tow bar on a moke at pick and payless today, the photos are in this album.
not sure if its bad, good or indifferent, but i thought i should share it.
Also got some pictures of the green moke some one mentioned here:
http://s83.photobucket.com/albums/j319/ ... ss%20Moke/
You're so square
Baby I don't care
PostPosted: Fri Jul 30, 2010 7:42 pm
bnicho wrote:
There are still afew 1 7/8 tow-balls and trailers around. A mate has a 1 7/8 ball on his ancient trailer. He forgot to change the ball once when he borrwoed my car trailer. The (fortunately empty) trailer jumped off on a bump and punched a neat hole in his rear bumper. :shock:
exciting stuff aye, i had a similar event with my fathers boat :lol: came off on a bump and carved into the bitumn.. hmmmm gotta love those safety chains...
PostPosted: Fri Jul 30, 2010 7:48 pm
Speaking of safety chains, it is a very good idea to attach the safety chains to the towbar itself and not just to the tongue. If a weld breaks or the bolts come loose on a removable tongue you could have a disaster.
If you attach the chains securely to a separate spot you can increase your safety margin.
PostPosted: Fri Jul 30, 2010 8:27 pm
Also make them short enough (cross two chains under the bar) to hold the trailer off the ground in the event
of the trailer becoming disconnected.
But still long enough to negotiate tight turns.
PostPosted: Fri Jul 30, 2010 8:50 pm
I dunno.... I was glad the chains ground themselves away and the trailer turned left when the dunny I was towing let go...
PostPosted: Fri Jul 30, 2010 9:53 pm
There will always be exceptions Simon......and thats certainly is one of them. :!:
PostPosted: Sat Jul 31, 2010 8:32 pm
Started measuring up for mine today.
Can anyone tell me what distance I should be aiming for between the ball and the bumper?
:D
PostPosted: Sun Aug 01, 2010 7:43 pm
^^^^don't know what other people have but an extra question is, How high is your tongue from the ground?
PostPosted: Sun Aug 01, 2010 9:10 pm
high enough that the doors just open and high enough that it doesent hit the ground. Im also in the process of lifting the car up at the back, to get more clearance for heavier traliers I have.
Users browsing this forum: Bing [Bot] and 172 guests
