It is currently Tue Aug 05, 2025 7:27 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 171, 172, 173, 174, 175, 176, 177 ... 568  Next
PostPosted: Sun Aug 01, 2010 7:16 pm
Saw it today
PostPosted: Sun Aug 01, 2010 7:26 pm
Rep;laced the hinges and the doors on the project.
Cut one of the front flares to fit around the hinge.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Aug 01, 2010 7:40 pm
Finally retired from work last friday (almost 55, but was offered lots of money not to come back!!) so made a big list of work (and parts) needed to get the clubbie on the road!
PostPosted: Sun Aug 01, 2010 7:42 pm
I finally started on Maysie's interior...so she now has a new dash complete with new Pioneer stereo and 2 four inch speakers and iphone connectivity, her new black rear seat covers, new black door cards all round, new back parcel shelf with speaker pods and two Pioneer 6 inch three-way speakers and although not mounted yet, the start of her bright red 6 point roll cage...
Pics speak a thousand words....
PostPosted: Mon Aug 02, 2010 12:03 pm
the wok broke on the way to drop the kids off at school!! Luckily another parent saw and took the kids the rest of the way for me
The clutch pedal went a bit wierd on Friday, I only had half a pedal, but I forgot to check it out on the weekend... went to take the kids to school and thought "bugger, I was going to check that" - put my foot on the clutch at a roundabout and nothing at all! bugger! (I sad a bad word in the car)
rolled around the corner and had a squiz, the clevis pin was hanging out (I put it in from the top, it had worked it's way upwards) and when I touched it, it fell off along with part of the wok. It had snapped clean through the clevis pin hole.... bugger!
So I drove home clutchless and replaced the wok, and was at work by 11:30 (had a coffee at home too)
the lesson here is "20 seconds to check something wierd can save a lot of grief"
PostPosted: Mon Aug 02, 2010 6:41 pm
I started it :shock:
For the first time in over a week.
PostPosted: Mon Aug 02, 2010 6:53 pm
Mods rock!
Do you think this was related to the clutch trouble you had on your way back from Hay?
PostPosted: Mon Aug 02, 2010 8:46 pm
nup, that was just the slave...
PostPosted: Mon Aug 02, 2010 9:06 pm
Mods rock!
PostPosted: Mon Aug 02, 2010 10:54 pm
Have spent this afternoon pricing up new pistons and rings for my little motor and getting myself mentally prepared to bash the pin out of the rod change so I can remove the engine.. :wink:
PostPosted: Wed Aug 04, 2010 2:44 am
Asphalt wrote:
simon k wrote:
I forgot to put oil in this morning, doesn't drive nicely... I still have the AFR meter so I might see what it's like, but doesn't feel good
We fitted a stronger spring to my carb when we removed the damper assembly. Though Des Hammill goes on about leaving the spring out in his 'SU performance manual', or fit a very soft spring... All I can say is that it works great and improved acceleration & throttle response a fair bit. And still get's me about 35-40MPG (imperial) :) (with a MG Metro-ish engine with stg1 kit).
Certainly a very interesting topic that can cause quite a lot of controversy (Hammill is the first I found to write on it) :lol:
Having said that, I think I might need a softer spring. Looks like the current one is to strong and pushes the piston down too much on full throttle... :roll:
Made a short video:
http://www.youtube.com/watch?v=gtSam0RgPl4
Also could rise a little higher, bu then I didn't rev it to the limit. So that might be OK with a weaker spring...
Well - that's what I did today. Had to repeat it a few times, damn cam got no display... Not that I did mind :D
Jan
PostPosted: Wed Aug 04, 2010 3:07 am
nice vid!
PostPosted: Wed Aug 04, 2010 4:56 pm
Pulled out the fully sick sub woofers and refitted the back seat.
"Ride hard or die trying"
PostPosted: Wed Aug 04, 2010 5:02 pm
dam don't remind me lol thats me MOnday
PostPosted: Fri Aug 06, 2010 5:44 pm
Pissfarted about trying get the exhaust and muffler to sit right and gave up
David L
Users browsing this forum: No registered users and 68 guests
