It is currently Sat Aug 16, 2025 9:12 am
PostPosted: Wed Aug 11, 2010 3:30 pm
hi guys, as title says, my clubby van needs new shocks all round for the big trip to SA in November, so where can I buy some good shocks, that are cheap but also good economy?
Overseas? Local? Anywhere, people tell me your advice?
I believe that the van's are different to the sedans for shocks?
Also whats the go with adjustable ones? gas or oil? whats all the go there???
Cheers Lockie
PostPosted: Wed Aug 11, 2010 6:17 pm
Mods rock!
Not trying to be a wise guy, but it's a bit like 'how long is a piece of string?'
It depends on what you want and expect from them. Standard shocks can be quite good and then you go from there. Stockies I usually get from Karcraft. Sports types I get from the UK. I have used Koni's, Spax's and Gaz - all very good but these days I feel that the Spax and Koni's are a bit dear, the Gaz seem to be good value for money - all of these are adjustable BTW however in this regards the Koni's are a PINA as you have to drop of one end of the shock to do so.
The fronts are the same as for a sedan but the rears are a little longer for a Van (same as Moke).
PostPosted: Wed Aug 11, 2010 6:27 pm
KYB are pretty decent. Good price and do their job. Most places can get them, some mini suppliers, shock absorber mobs, even autobahn/supercheap etc can get them for you. These aren't adjustable though.
PostPosted: Wed Aug 11, 2010 7:21 pm
in terms of adjustable, does that adjust the ride smoothness?
PostPosted: Wed Aug 11, 2010 7:30 pm
if you want ok for price
http://www.minisport.com.au/prod3.htm
i put these in and they are fine. I am intending on destroying them on the tanami track, but for normal road purposes, they are fine.
PostPosted: Thu Aug 12, 2010 9:51 am
I have put pedders shockies in my moke for standed shocks they seamed to be quite good and they are well priced
Don't under estimate the power of a Mini
1975 Supercharged Blue Mokezilla ;)
1976 Fudge Moke
1967 BRG & White 67 Morris Deluxe
1974 Clubman Mini S
2005 Red Mini Cooper S
2009 Mitsubishi Outlander VRX
PostPosted: Thu Aug 12, 2010 3:10 pm
Monroe make a basic oil one, that is reasonably cheap and excellent quallity. KYB make both: gas and oil and adjustable oil but when I asked I couldn't get adjustable for the rear only front. Apparently they dont make them but ask around.
Gabriel and Peddars are the same brand, cheap chinese (taiwanese technically I think) and I would stay away. Go with a decent brand. more expensive but will last heaps longer so it evens out.
Just google for failures in the chinese shocks, you are lucky if you get more than a year.
Id hit up autobahn etc first, they should be cheaper than most of the aussie suppliers and fathers days coming so expect a 20% off sale. UK is even cheaper but you need to get a few things to make postage worth it.
PostPosted: Thu Aug 12, 2010 5:32 pm
i agree with you kirby, i had fathers day in mind specially :P :lol: but also got a bunch of stuff I need to get from the UK, but I've been advised by a friend that postage JUST for the shocks will be $100 or more... :shock: haven't yet looked into seeing if thats the case or not,,,,,,
thanks heaps for the tips, been very useful guys :D
 Post subject: Shockies for Mini Van.
PostPosted: Thu Aug 12, 2010 6:28 pm
Try any Repco branch.
"Let us remove your "SHORTS"
PostPosted: Thu Aug 12, 2010 8:39 pm
I should hope it wouldn't be 100 for postage, I had a set of springs hilos and other bits for under 50 sent via her majesty's mail. they are small shocks and there isn't all that much weight in them.
Don't forget it will likely be something that needs ordering so if you are on a deadline consider that when going the chain store route.
PostPosted: Thu Aug 12, 2010 9:04 pm
yeah, need it for this time next month or so, so getting in quick.
I checked it out and postage just for the shocks ranged from 80 to 109ish..
tho if I added the other stuff im buying with it, it hardly changed it at all, so i guess that's not so bad, you have to get other stuff with it as you say to make it worth while..
PostPosted: Fri Aug 13, 2010 7:00 am
repco is actually ripoff expensive when it comes to shocks for a mini.
PostPosted: Fri Aug 13, 2010 2:17 pm
What where they asking for shocks?
Users browsing this forum: No registered users and 325 guests
