It is currently Mon Jul 21, 2025 3:43 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Mar 30, 2005 10:59 pm
czerial wrote:
thats the same as viv....
I thought you were about to say Viv was the same as Mini Ha Ha.... :lol: :wink:
PostPosted: Wed Mar 30, 2005 11:00 pm
:lol: :lol: :lol: @ Anton, your stupid :lol: :lol:
isnt HaHa the one with a quick motor and a funnny front.....
owned by a Dr as well..
PostPosted: Wed Mar 30, 2005 11:01 pm
hey Chris...did you get your MCC mag today?
PostPosted: Wed Mar 30, 2005 11:08 pm
i did, am going to read pops article when i hit the sack, havnt had a read, just flicked through this arvo :wink: anything else of interest in there?
PostPosted: Wed Mar 30, 2005 11:13 pm
nah mate, just Pops :wink: :lol:
PostPosted: Wed Mar 30, 2005 11:14 pm
i shall go read it now (instead of chapter 5 in "accounting info for managers" uni work :x ) night all
PostPosted: Wed Mar 30, 2005 11:15 pm
The old fella gets around, doesn't he?
PostPosted: Wed Mar 30, 2005 11:17 pm
yea, gets around well for an old bloke.... :lol:
PostPosted: Wed Mar 30, 2005 11:18 pm
He'll have to go to the british mags next!
PostPosted: Wed Mar 30, 2005 11:23 pm
was to be the feature car on a pommie website next month :wink:
PostPosted: Thu Mar 31, 2005 9:36 am
I was able to connect a smiths tacho I bought straight up to my 78 and 73 clubmans using the two white wires as 1310/71 (I think) described I also had to hook up power and earth as well but that is to be expected. I was only putting it in the 78 to see that the tacho worked so there was no special wiring.
The two white wires come from the ignition and don't connect up into the loom that goes to the other dash instruments. Both of my clubbies have had the appropriate wires. 8) I am pretty sure both were designed with a two pod dash in mind (it's a bit hard to tell with one of them it's been heavily modified and I don't think the wiring is very standard anymore :roll: )
Roads need more corners
PostPosted: Thu Mar 31, 2005 10:13 am
so which model was it that came with the actual clock, and not a tacho?
PostPosted: Thu Mar 31, 2005 10:50 am
My loom is 100% standard. I will check it out, as I need to reconnect all my gauges and switches very sooooooon :wink:
PostPosted: Thu Mar 31, 2005 11:49 am
i know my 3 clock speedo is not standard which is what confuses me. when i had it out the other day the wire that connects to the tacho had been put in by someone and it just connected to the coil. but then i saw another wire which was part of the wiring up to the speedo and it had the same clip as the tacho i dicided to try it and it worked perfectly. so i removed the wire that had been put in (the one to the coil) an put the speedo back in using the wire off the wiring harness. what confuses me is that my clubman is juat a basic one and didnt come with a 3 clock so maybe all the wiring was the same in all clubmans :?
PostPosted: Thu Mar 31, 2005 1:31 pm
resident alien
resident alien
Red line gives tacho power, blue backing stuff earths the tacho where the red dot is and green line goes to -ve of the coil... helpful or have I misread the thread?!
