It is currently Wed Aug 06, 2025 3:08 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 176, 177, 178, 179, 180, 181, 182 ... 568  Next
PostPosted: Tue Aug 24, 2010 8:19 pm
gibbo123 wrote:
that always makes me nice and moist...
And that just makes me squeamish.
You're so square
Baby I don't care
PostPosted: Tue Aug 24, 2010 8:23 pm
Modified 2x 3rd motion shafts (14mm nose) to be 18mm nose, repaired another worn 14mm one to be still 14mm.
All 3 now have nice shiny new roller bearing inner rings fitted. :P
PostPosted: Tue Aug 24, 2010 11:01 pm
Apologies :P
PostPosted: Sat Aug 28, 2010 9:41 am
Got the Clubman Estate back from the brake guys. It's upgraded to vented metro disks with a booster. I didn't want to run the additional lines for the booster so left that to them and just as well I did. They had heaps of trouble: the booster wasn't reconditioned as I had been told it was, the hoses for the metro disks, although new, weren't quite right, the M/C had to be bored out and a few other bits and pieces. However, it now has savage brakes and I can crack on with the Gp 5 flares, tidying up the paint etc.
PostPosted: Sat Aug 28, 2010 10:24 am
started making a little mold.
mooo, I'm a pig!
PostPosted: Sat Aug 28, 2010 11:23 am
I see me taking it for a short blast out around the local roads...and an illness in the family too..rub another coin across my palm..
PostPosted: Sat Aug 28, 2010 5:49 pm
stuff
PostPosted: Sat Aug 28, 2010 6:39 pm
lots of etch primer
ANY SEA ANY TIME
PostPosted: Sat Aug 28, 2010 6:59 pm
figured out why i ddint have power at my coil and hence spark - ended up being the power from the ignition went to the tacho and then stopped, it wasnt continued from the exiting cable.
Now i need to change tachos over
Happy i could figure it out
PostPosted: Sat Aug 28, 2010 7:00 pm
Modified a new brake pressure limiting valve to adjustable, for Mini Mad.
PostPosted: Sat Aug 28, 2010 7:12 pm
slapped it a few times.
Mysterious flat spot developed while parked last night, was driving fine, got home, parked, went to drive it 3 hours later, now under load it sounds like a subaru wrx with 3" exhaust system.
have checked dashpot oil (topped it up, it was empty :roll:), adjusted idle mixture a little, checked plugs, electrodes brown, not wet and oily..
is running megajolt, so not sure how timing could be out... perhaps the coil pack is failing? Manifold leak?
Will look at it when back from overseas in a couple of months.
tim
PostPosted: Sat Aug 28, 2010 7:16 pm
well the other day fan flew to pieces and hit my alloy radiator from ebay but didnt puncture it miricle i know.......so any way i stopped on the side of the road and changed fan over with another was goin to a mates to do it but got to hot on the way so side of the road job it is.....this was on wednesday sry 4 delay
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Sat Aug 28, 2010 9:03 pm
Put a seal kit through my clutch slave; honed up nicely after a huge pile of gunk came out of it. No more fluid squirting out the dust boot. yay!
Steven
Gave Sues daily drive a Oil Change. Sue also mention that the brakes had a noise in them the last few weeks. Orderd the pads during the week and collected them this morning. Went to putting them on and :twisted: wrong EBC Black Pad.Not happy Jan. Dr Mini I am very lucky to have near by as he has come to the rescue again.
Didn't get to touch Marcia today but did purchase front 1 piece windscreen rubber, both master cylinder pipes, Clutch Muster pipe/hose bolt & anti rattle washer, Voltage stabilizer (should have organized from wombat earlier:roll:) , Oil pressure dial connection & hose, Fan Belt and 1 last thing a Go Peddle cable
Also Collected a Sump Gaurd and during the week a AC17 Alt
PostPosted: Sat Aug 28, 2010 9:45 pm
installed pedal extension, electronic conversion for the dizzy, new speedo cable and headlight switch for my fog/driving lights.
tomorrow ill hopefully be working on the tune and getting it driveable for gannons
Users browsing this forum: Bing [Bot] and 75 guests
