It is currently Tue Jul 29, 2025 8:22 pm
 Post subject: 23d4 distributor
PostPosted: Wed Sep 22, 2010 3:42 am
My mini runs a 9FXEY stamped 1275 with a 23d4 dissie, unfortunately the base of the dissie has a crack in it, still runs ok but probably wont last long. It appears that finding a replacement 23D4 will be difficult.
Any recommendations for a replacement electronic type or other?
The cam spec of the motor is not known.
Thanks to anyone who can help.
PostPosted: Wed Sep 22, 2010 7:02 am
Mods rock!
To retain a points system get one from these guys
http://www.performanceignition.com.au/home
Uses easy to obtain and highly reliable Bosch parts.
These can also be supplied in an electronic version.
PostPosted: Wed Sep 22, 2010 9:57 am
Brand new 23D4:
http://www.holden.co.uk/displayproduct. ... Code=40819
They deliver to Australia
PostPosted: Wed Sep 22, 2010 2:13 pm
Lillee wrote:
Brand new 23D4:
que?
A new Distributor is no longer available, but we offer to rebuild your own Distributor.
on Dad's 23D4, the base had cracked around the flange from being clamped too tight, I built it up with metal epoxy stick stuff and it's been good for 2-3 years
PostPosted: Wed Sep 22, 2010 2:32 pm
que?? :?
PostPosted: Wed Sep 22, 2010 3:04 pm
Lillee wrote:
Brand new 23D4:
From this link "A new Distributor is no longer available, but we offer to rebuild your own Distributor."
Not a lot of use if his housing is buggered :wink:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Sep 22, 2010 3:13 pm
oops :oops:
PostPosted: Wed Sep 22, 2010 3:18 pm
Lillee wrote:
oops :oops:
hence the "que?" ;)
PostPosted: Wed Sep 22, 2010 3:51 pm
Mods rock!
There are a lot of places here in Oz who can recondition one, so why go to the UK??? but as Panthersteve points out ^^ no use if the body is cracked.
PostPosted: Wed Sep 22, 2010 4:07 pm
depends on the crack... like I said, some metal epoxy stuff, or weld it up. It's worth saving
PostPosted: Wed Sep 22, 2010 7:42 pm
It's only alloy, about 5 mins work for someone to TIG weld it.
They crack because they are hollow underneath the clamp ring.
If you wanted another dizzy I'd get a 43D4 from a later Oz Mini, and put a Britparts or Pertronix electronic kit in it.
I have one running great in my 1412 stroker, same advance curve and all.
No more *(*^&&()-0 points..... :evil:
PostPosted: Thu Sep 23, 2010 8:06 am
They crack at the base because people don`t realise that they need to loosen at least one of the base clamp retaining bolts before they play with the pinch bolt
The clamp will pinch into the body of the dizzy & wreck the thing
so,,, everyone listen up,,,, """FIRST you need to LOOSEN at least one of the 2x clamp retaining bolts,,, then release the pinch bolt to sort your timing,,, then re-tighten the pinch bolt (only needs to be NIPPED UP ---> & THEN tighten the clamps retaining bolt
it`s not difficult to do it correctly & saves wrecking all those "hard-to-find" distributors
