Answering my own question - the hole in the alternator is metric threaded at 8x1.2
What would people do? If I leave it metric it will be the only metric bolt in the whole car or should I take it out to 3/8" and re tap it UNC ?
On another note my original alternator was mounted with a single long bolt through the top holes - but the correct mounting is two separate bolts - is there a reason for this?
( I found a nice fat washer too work as a packing piece - just right
David L
