It is currently Fri Jul 11, 2025 7:55 pm
 Post subject: mini K sprint car
PostPosted: Sun Sep 26, 2010 9:23 pm
Hi, guys.. my mate and I have just about bought a shell for a Sprint car.
where can we find the specs for a sprint mini. ie what we can do and what we cant do.
ie suspension, mmotor etc...
PostPosted: Mon Sep 27, 2010 9:21 am
what do you mean by "Sprint" - as in club racetrack sprints? go to www.camsmanual.com.au
club sprints are usually fairly open, but if you stick with off the shelf stuff you're safe
PostPosted: Mon Sep 27, 2010 11:51 am
I think he means speedway?
PostPosted: Mon Sep 27, 2010 11:59 am
I thought he meant street sprints like they do at Lakeside. If that is the case then I think you can basically do what you want as long as they scrutineer it as being safe.
Probably makes more sense to do it to group N regs though, it either gives you more opportunities for using it or gives you some value for resale if you have enough of it.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon Sep 27, 2010 6:50 pm
and being a Mini K you'd be looking at Nc class which gives you more freedoms than Nb. Grab a current CAMS manual.
PostPosted: Mon Sep 27, 2010 7:10 pm
no i am after a race mini for Leyburn
PostPosted: Mon Sep 27, 2010 7:53 pm
As has been said, you have a fair degree of freedom, no need to comply with the Group N requirements, eg can run polycarb instead of glass (except for windscreen). However, roll cage, seat mounts, harness mounts, fire extinguisher, oil catch can etc are best made to comply with CAMS requirements, which can be found in the Manual. Can run 1380 or 1430 no problems.
Steve
PostPosted: Mon Sep 27, 2010 9:08 pm
so essentially we could roll up with a mini K with the above saftey items and race it? :shock:
PostPosted: Mon Sep 27, 2010 9:59 pm
yep, provided it is sound, mechanically and bodywise, and it passes scrutineering. Read (and understand) the Regulations and any Supplementary Regs for the event you intend to enter, and follow them.
Steve
PostPosted: Tue Sep 28, 2010 2:31 pm
for a sprint, it can be a standard road car - no need for a cage, race seat, belts etc. - it's accessible low budget motorsport...
a safe road car with a fire extinguisher, and you with a helmet
PostPosted: Tue Sep 28, 2010 9:04 pm
yep had a chat with Minimad the today and said some interesting stuff. Ie Sponsorship logos etc.... it was brilliant to chat to some one who does it!
Thanks mate.
