It is currently Fri Jun 20, 2025 6:36 pm
 Post subject: brakes
PostPosted: Mon Sep 27, 2010 10:04 pm
ok guys just to clear this up i have standard wheel cylinders on the back of my brakes and i got 7.5 disk brakes on the front reco master cylinder do i have to put the smaller wheel cylinders on the back to get better brakes or i should have good brakes dont matter which size i run at the back
PostPosted: Mon Sep 27, 2010 10:26 pm
Online
In my experience, it will lock the backs up under heavy braking. This is bloody dangerous in wet weather on a freeway,as I found out on the F3... :shock: Nope I missed all the roadside furniture & mobile chicanes.
If I'm fitting ANY front discs I'd fit new 5/8 rear wheel cyls at the same time. :wink:
PostPosted: Mon Sep 27, 2010 10:29 pm
The brake pedal should develop pressure with less travel with 5/8th on the back (making it "feel" better). And as drmini suggested it can be dangerous without the right size as i found out as well.
PostPosted: Mon Sep 27, 2010 10:46 pm
i have no boster if this changes anything
PostPosted: Mon Sep 27, 2010 11:24 pm
Nope... Just means you don't have to push the pedal as hard for the same braking effort.
PostPosted: Mon Sep 27, 2010 11:31 pm
It matters which is at the back! S brakes need S rear cylinders as per Doc's post. If not, 360 or 720 under hard braking...
Lillee - 1969 Morris Mini K
PostPosted: Tue Sep 28, 2010 10:07 am
When I first got my car, I had a different sized cylinder on each side :shock: :shock:
As the others say, you need the smaller size.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Sep 28, 2010 8:03 pm
Also don't forget to adjust your rear brakes
Users browsing this forum: drmini in aust and 91 guests
