I've kept this quiet till it was finished - only about 8 people know, but it's out there now
Funny story behind this, about 6 years ago my mate showed me this little supercharger and said "here you go, see if you can put this on your mini", then a few weeks later I went to Hay, and here was this blue mini with the same blower. I spoke to the guy who set it up, who turned out to be Ben who is making the kits that are doing so well now!
Then I got busy, didn't get around to it and my mate took the blower back to put on a Volvo or something, but that didn't happen either, and it showed up again in the corner of the workshop a couple of months ago.
My mate was going away, and I joked that I could teach myself to weld aluminium with his AC/DC TIG while he was away - but he liked the idea, gave me the TIG to take home, and gave me the blower and said it was mine if I could get it on the brick by the time he came back - well he came back about 3 weeks ago, it was sitting on the car but not running - but close enough
Anyway - I asked Ben if he minded if I copied his ideas from some photos, and made my own setup... in reality there's basically only one way to do it. I had some design parameters though, it had to be aluminium, I needed to keep my hydrolastic suspension and heater, no cutting of bodywork, needed to use a REAL air filter, and I only wanted one fanbelt.
I'm broke so I did it CHEAP - using as much scrap and leftovers as I could. The most expensive bit was the air cleaner box, but dad paid for that, and for the head gasket - he owed me for giving him my reco harmonic balancer
SC12 blower 0
alloy channel for plenum 0
alloy tube for intake 0
alloy for relief valve 0
alternator and intake bends 45
welding rods 31
alloy for idler bracket 10
alloy for BOV inlet & circlip 5
landrover water pump pulley 0
nissan(?) idler pulley 0
fan belt 34
2mm head gasket 80
Getz air filter box 100
air fittings 20
radiator hose for intake 15
gemini starter motor 45
carb jet (+ freight!) 32
total cost $417
here are some pictures
modified alternator bracket to mount the alternator lower down
completed install - just waiting for a replacement PCV to plumb in the breathers
there are two idlers, one to bring the belt up from the crossmember, and another to push it down under the head. It's tensioned by the alternator
some 'during' pictures
the alternator and the standard mini harmonic balancer machined down with a landrover discovery diesel water pump pulley fitted. The alternator is off a Subaru of some sort - dunno what, but it was the best one for the job I wanted. I made the water pump pulley (not pictured) by machining down the standard mini water pump pulley and welding on the ring from something else (maybe nissan, not sure). It's not perfect, but it'll do
just some pics while I was making the intake side
and if anyone is curious about what the SC12 looks like from inside, here you go
air goes in here
the pulley is attached the other end of one of these, and it turns the other one
which turn these around and squish the air (or air/fuel)
it's going really well - I'm sorting out some bits and pieces before a motorkhana on Sunday... and I can weld aluminium now - some of it is a bit manky, but the more I did the better I got with it
