It is currently Wed Jul 30, 2025 9:27 pm
PostPosted: Fri Oct 29, 2010 6:32 pm
I must have done a better job of putting the tank back this time and it it tucked in nice a snug but the retaining strap bolt is nigh on impossible to reach - what do people do/use to tighten it up?
David L
PostPosted: Fri Oct 29, 2010 6:34 pm
Online
3/8 drive 1/2" socket and extension bar.
PostPosted: Fri Oct 29, 2010 6:40 pm
Tried that - can't get in the top real good - just thought might try the universal joint connection to follow the curve of the tank around so to speak.
David L
PostPosted: Fri Oct 29, 2010 6:42 pm
I use a uni joint on a 3/8th drive. I use a rattle gun (suitably turned down) to get it straight without pulling sideways.
PostPosted: Fri Oct 29, 2010 6:43 pm
Mods rock!
I use a 1/4"Drive set with a looooong extension (about 500 mm long) and a 13mm socket. 1/2" is the correct sixe but the 13mm is a little bigger so doesn't need to line up as accurately.
PostPosted: Fri Oct 29, 2010 7:57 pm
PO on my blue clubman used a 50mm roof screw. I won't tell anyone that I put the tank back in with the same roof screw.
PostPosted: Fri Oct 29, 2010 8:01 pm
I won't, its not like this is the internets or anything :P :P
Users browsing this forum: drmini in aust, lomin and 95 guests
