It is currently Thu Aug 07, 2025 6:38 pm
 Post subject: Points Dizzy
PostPosted: Tue Nov 16, 2010 11:06 pm
So the distributor has points in it but there is no vaccum advance how can i tell if there is some other mechanical advance built into it or if its just a dodgey distributor? its not picking up power under load like it should.
Thanks in advance.
MINE:
1976 Clubby 1100, 266 Kent cam, slightly worked head. (awaiting paint)
1978 1275LS Hi-Ho Silver with a Camtech 619 cam and some strange looking rockers
 Post subject: Mechanical advance
PostPosted: Wed Nov 17, 2010 6:08 am
Easiest test is to take the Cap off and see if the rotor button can be rotated by hand a few degrees with the engine stationary of course and make sure it also springs and returns back to the original position.
"Let us remove your "SHORTS"
 Post subject: Re: Points Dizzy
PostPosted: Wed Nov 17, 2010 7:54 am
minimuts01 wrote:
Thanks in advance.
He he... :lol:
 Post subject: Re: Mechanical advance
PostPosted: Wed Nov 17, 2010 9:32 am
yeah so it rotates a few degree and springs back to the original position.
here's some pics:
MINE:
PostPosted: Wed Nov 17, 2010 9:35 am
my dizzy was like that. only had mechanical advance :( but then I bought a new dizzy which had electronic ignition and vac advance. and holy moley it makes a difference having vac advance lol :)
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Wed Nov 17, 2010 10:38 am
what sort of difference?? vacuum advance is for economy - IE it advances when there is vacuum in the manifold, IE when you're only lightly touching the accelerator. Put your foot down and it goes away
I think your "holy moley" is from the electronic ignition, and the dizzy not being worn out :wink:
PostPosted: Wed Nov 17, 2010 6:28 pm
I also bet your new fangled dizzy also has mechanical advance.
So-called `vacuum advance' is only a part throttle economy device. it has no other function. If you have a sporty cam with more than about 270° duration, it won't work anyway. :lol:
