It is currently Fri Jun 20, 2025 2:55 am
PostPosted: Wed Dec 01, 2010 11:26 am
Wondering if I should upgrade to a hi torque starter motor. Barney seems to labour a little at startup and I think a nice whirring geared starter might do the trick. Ideas?
PostPosted: Wed Dec 01, 2010 5:32 pm
Pre-engaged would need a different ring gear (A+) or why not, a lightened flywheel and ring gear? really should be balanced then though.
I assume you can get Hi torq to suit a series ring gear I think Tony (MiniConvertible) up in QLD can sort you! 8)
Sir Alec! we are not worthy!
PostPosted: Wed Dec 01, 2010 6:13 pm
Barney already has a new geMini starter, if you are having problems it's time for a new battery mate.
It is pre-engaged already, using the early mini ring gear, NOT the later Rover one.
This starter spun it like a top when the battery (Exide 550CCA) was new. Maybe Marc changed the battery, or it's had it...
C/R on your 1293A+ motor (21251 pistons, slightly decked head) is only about 9.0:1. Spinning it over is not a problem. :wink:
 Post subject: starters
PostPosted: Wed Dec 01, 2010 7:25 pm
Also check your terminals and all power cables going to the starter... and while your at it check all of your earth straps.
PostPosted: Wed Dec 01, 2010 7:45 pm
I know someone who installed a switch so you spin the motor up before you power the points :wink:
PostPosted: Wed Dec 01, 2010 8:22 pm
Yeah do tell, but he has to run 38° total advance due to the bathtubbed head shape and big cam. Which means static timing with the GR modded Pulsar dizzy is about 20°BTDC. No, it doesn't ping either. :P
PostPosted: Thu Dec 02, 2010 9:15 am
Will start with a battery then. I know the old man had to give it a charge when I was in Canada as it would run flat about every 10 days. I thought it may have been something to do with the advance, but a battery is a good place to start.
PostPosted: Thu Dec 02, 2010 9:21 am
I put an Exide 550CCA in when we bought it so if that's still there, it's a few years old now.
I have the same type battery (same age too) in my 1360/1412 car, this past winter I went very close to changing it for the same reason. But if I drive it once a week it'll survive until May next year. 8)
If you buy a new battery, get the biggest output one that'll fit in there. Similar to what I said above.
Last edited by drmini in aust on Thu Dec 02, 2010 9:23 am, edited 1 time in total.
PostPosted: Thu Dec 02, 2010 9:22 am
Well Barney runs every day, so there's life in the battery yet. Will stick it on the list. Doc, are you planning on going to Oz50 at WP?
PostPosted: Thu Dec 02, 2010 9:24 am
Yeah we'll go for a look, but I'm not going to get a CAMS licence just so I can do some laps. :wink:
PostPosted: Thu Dec 02, 2010 9:25 am
You can get an AASA licence for $50. I'm going to run Barney in reg (at a spirited, yet relaxed pace).
