It is currently Thu Jul 24, 2025 7:54 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 03, 2010 9:26 pm
knuts2au wrote:
Will be seeing the engineer for inspection next Wednesday and i will clarify if you can substute the original mounting bolts for eyelet type bolts,( so the eyelet holds your original belt in place) the premises being that your either using one belt or the other. In my case this was not practible due to the way they mounted.
Thanks. Will be interested to know.
PostPosted: Sat Dec 18, 2010 3:57 pm
Finally got a reply from the engineer, he can see no problems with replacing standard seat belt bolts with eyelets for a harness providing they are a direct screw out /screw in replacement. Had no problems with my SAAS seat, he was happy with my mounting method (70's Volvo) main thing is to use crush tubing if bolts go thru pipe/ box sections.
PeterN
3x Leylands
1x 850
Mildura,
Victoria.
Users browsing this forum: Bing [Bot] and 90 guests
