It is currently Fri Aug 15, 2025 4:47 pm
 Post subject: Fuse Boxes
PostPosted: Sun Dec 12, 2010 4:28 pm
Die Die Die!!
my external Rover (glass type) fuse box is getting old and begining to stop working..
has anyone installed a late model Rover (blade type) internal fuse box on an earlier external fuse box loom ?
PostPosted: Sun Dec 12, 2010 4:40 pm
It's not a job most people would do. The easier thing for you would be to install a blade fuse type setup (mounts on firewall) in the engine compartment like the factory did till 96.
 Post subject: Fuse box
PostPosted: Sun Dec 12, 2010 8:49 pm
Try and stay away from Blade fuse type fuse boxes. They are not very good at handling current and create voltage drops. Try and find a Glass fuse type box they are a better fuse box. NILES make a good 4 gang fuse box.
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 289 guests
