It is currently Wed Aug 06, 2025 10:40 pm
PostPosted: Mon Dec 13, 2010 8:28 pm
hi. just looking to do this incase when my sc12 go's on.
im not having any over heating problems.
how is this plumbed up? and can i still retain my heater?
can i use a heater core from another car???? any others??? motorbike rad?
has anyone got any pics of how it is done?
PostPosted: Mon Dec 13, 2010 8:34 pm
im guessing you just tap into your heater line any where convinient and use whichever one fits the fittings easy stuff
PostPosted: Mon Dec 13, 2010 8:37 pm
Give Ash some flowers Nick .
I installed a Honda CR80 radiator in mine (just one side). I figure it has to cool better than a heater core - it was designed to cool water, not heat air.
That's what I did. I would plumb it in after your heater so your heater stay's hot. I even put some computer fan's on it to come on with the thermo fan.
PostPosted: Mon Dec 13, 2010 8:47 pm
yes i thought about that also.
where did you get that from?
i have been looking on ebay. for a few with the overflow nip, did you just weld to blank it off?
PostPosted: Mon Dec 13, 2010 8:48 pm
Mods rock!
I'm sure others have shown 100 and 1 ways of plumbing in an auxilary radiator.
But
Since yr in Brissy, how come you want a heater?
PostPosted: Mon Dec 13, 2010 8:56 pm
winter does get cold GT lol..
it's shocking??? can you believe brisbane gets cold.. :)
PostPosted: Mon Dec 13, 2010 9:03 pm
Mods rock!
You've been there too long!
How's yr wagon going anyway?
PostPosted: Mon Dec 13, 2010 9:14 pm
it's going very good.
comfy ride ;)
just want to do this extra cooling.
im tossing up with a heat core or a small bike rad.
looking at this
http://cgi.ebay.com/ebaymotors/aluminum ... 1737wt_941
or
http://cgi.ebay.com/ebaymotors/Universa ... 1293wt_941
or just the small little heat core. will be running thermo fan no plastic fan.
PostPosted: Mon Dec 13, 2010 9:21 pm
Mods rock!
Glad it's going well for you and yr happy with the suspension.
IMO, the first rad is the better of those 2, but I'd also suggest looking for a copper one.
The second one is too thick to be of any real value.
PostPosted: Mon Dec 13, 2010 9:25 pm
yep going with the first link, lets see if he will separate.
the other one is just to big.
PostPosted: Mon Dec 13, 2010 9:30 pm
Just make sure it has 1/2" outlets otherwise you will also have to buy adaptors to make all the hoses mate up. That's why I picked mine.
PostPosted: Mon Dec 13, 2010 10:35 pm
Supercharged
i think a lot of us have clubby heater cores because we had them lying around spare?
PostPosted: Mon Dec 13, 2010 11:02 pm
did you use one on the charged mini?
PostPosted: Tue Dec 14, 2010 12:39 am
Supercharged
yer
PostPosted: Tue Dec 14, 2010 12:34 pm
ive used a heater core in the past... it works fine, however you have to ensure you have a good water pump, as you are expecting the water to be pushed around much much further and you need to keep the flow happening or else your going backwards... my 2 cents :wink:
