It is currently Fri Jul 18, 2025 3:02 pm
PostPosted: Fri Dec 17, 2010 12:09 pm
I disassembled my rear subframe a few months ago, and now going to put it back together ive found the threads on the end have been crushed.
Ive tried running a die down it, but it wont grip.
Anyone have any ideas how to fix or is it a replacement job?
Joe
Simplify and add lightness
PostPosted: Fri Dec 17, 2010 12:27 pm
Run a thread file over the first two "crushed" parts of the thread, then run the die nut down it.
PostPosted: Fri Dec 17, 2010 1:54 pm
Mods rock!
You need to know how to hold it without damaging it?
Get two blocks and soft wood (not too soft, I use oregan), say 4 x 2 x 4" long. Clamp them together (so it ends up 4 x 4 x 4) then use say a 11/16" speed bore and bore right through on the joint between the two block. When you take it out of the clamp, you'll end up with half a hole (like a trough) across each block.
Then you can lay your pin between them and put it in the vice, clamping them back together again. Tighten the vice as much as you like, you won't hurt the pin.
These pins are 13/16" dia and the threads are 1/2" UNF.
PostPosted: Sat Dec 18, 2010 10:45 pm
aluminium soft jaws in the vice and carefully file the bruised threads off the end and then use a die nut. The best cutting lubricant ever made is good old lard from the supermarket. It's all we used during my apprenticeship and I still use it today. The old type of trefelex was based on this until some "do gooder" changed it.
www.minisprintgt.com
PostPosted: Sun Dec 19, 2010 7:38 am
Don't screw with animals
David L
PostPosted: Sun Dec 19, 2010 7:41 am
What a top idea !!
PostPosted: Sun Dec 19, 2010 1:56 pm
Carcinogenic fumes, you can still use it, but you're not allowed to get it hot enough to smoke (yeah no worries :roll: ) .... but it is still the best stuff. Rocol is pretty good too.
