It is currently Sun Jul 20, 2025 12:12 pm
PostPosted: Thu Dec 30, 2010 2:38 pm
I think it's a english thing my UK 997 has the switch Micks asking about
PostPosted: Thu Dec 30, 2010 4:19 pm
Well I've scored a potentiometer from jb007 (Thanks a million Jim). I'm unsure at this time if I should use it or not however pending a few questions.
So if the switch is under the bonnet, am I to assume that the driver chooses to operate the heater at the beginning of the trip and leaves it on? The heater flap modulates the flow? Am I supposing that some markets/models had the potentiometer fitted, and others just had the switch?
PostPosted: Thu Dec 30, 2010 5:15 pm
As far as I know none of the 997 Coopers used a rheostat to control the heater speed. The heater tap is the top hat type shown in the pics although I have seen the brass tap type in some very early photos.
With the 997 Cooper with the blower in the engine bay it is switched with the switch directly below the ignition switch. Check for the 2 mounting holes in the lower dash panel at this point.
The switch panel has the air control cable at the LH end and the heater tap cable at the RH end of the switch panel. The choke cable is mounted next to the steering column (see pic) and the windscreen washer pump is mounted on the LH side of the dash.
I have the original loom and there is no provision for the rheostat. The heater fan is simply switched and a separate loom runs from the switch directly to the fan motor.
PostPosted: Thu Dec 30, 2010 5:20 pm
My English 997 uses a different heater than the Aussie ones it is a square box with the motor built into it my Aussie one is what wild willy's describing
PostPosted: Thu Dec 30, 2010 5:46 pm
The pics are from an early English 997 Cooper. Sounds like your may be even earlier Gold-brocade. I know the very early Smiths heaters sold as a kit for the 850's used a square box heater with the fan built in. Any chances of some photos of your English set up?
PostPosted: Thu Dec 30, 2010 5:54 pm
Ah now I get it, I missed the switch position..
Thanks again for the help Wild willy. Apart from the air control flap, I think I might have enough to fit this out properly. But were you telling me there may be another source for a air control flap from a triumph of some sort?
PostPosted: Thu Dec 30, 2010 5:59 pm
I have one from a 1953 Standard Vanguard ( the heater box with flap ) , if you want a photo just ask
74snail wrote:
I have one from a 1953 Standard Vanguard , if you want a photo just ask
Ahh yes please, thank you.
PostPosted: Thu Dec 30, 2010 6:07 pm
Mick The flap I used was from an Austin Healey. Had to do some metal fabrication to get it right as the flap didnt have the correct angle. Still need to find the right mesh for the front.
A place in UK makes repro flaps for AH 100/4 which look to be the same. Do you have the cable to control Air and the heater tap?
PostPosted: Thu Dec 30, 2010 6:17 pm
If you want it , it will go cheap
PostPosted: Thu Dec 30, 2010 7:14 pm
No I don't have the early control cables, I have a couple of the later Mk1 control cables for the heater tap and choke, and as you have seen the super early choke knob.
What's the name of the place supplying the air control flaps may I ask?
Thanks for the photos snail!
PostPosted: Thu Dec 30, 2010 9:07 pm
Mick check out the 100-4 bits here. The air flapper looks to be angled correctly as well. I'm also wondering if the air control cable might be correct for the Cooper as well. My guess is that BMC may have pulled something off the shelf for these early Coopers.
Might ask them if they can send a pic?
http://www.englishparts.com/showAssembl ... ly=AHY-094
PostPosted: Thu Dec 30, 2010 9:32 pm
Imagine opening up an Ikea box to find this as an instruction set!
PostPosted: Thu Dec 30, 2010 10:26 pm
Is this any help?
http://cgi.ebay.co.uk/SMITHS-OPTIONAL-HEATER-UNIT-FIT-STANDARD-8-10-/330513278566?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cf4206666#ht_500wt_1156
PostPosted: Sat Jan 01, 2011 10:07 pm
Hi Guys, been busy the last few day, but wanted to add to this...
I have a crinkly knob too!:
No rheostat that I know of, only the switch as described by willy:
My Blower:
My Heater:
Mine has a 'Push Air' Cable:
Original Flap Valve:
I did find this and bought it, very close!
Lots more stuff here:
http://s2.photobucket.com/albums/y10/gr ... 7%20Stuff/
willy is spot on with his info here, he's probably seen more of these than anyone!
Did find this oddball? May be european spec:
Cheers!!
Graham 8)
Sir Alec! we are not worthy!
Users browsing this forum: No registered users and 68 guests
