It is currently Mon Jul 21, 2025 7:49 am
 Post subject: 1 1/2 SU needle
PostPosted: Fri Dec 31, 2010 10:23 am
Hi all,
Just wondering roughly what the correct needle would be for a 1275 which has been bored to 1310 with ground cam?
Just for running in,
your help is much appriciated
James
1978 1275 LS silver 3rd palce mini Oz50 LS,SS,GT Class
1970 MORRIS MINI K 1100 3rd place mini50 pre '71 Class
Rover BBQ..... ;)
PostPosted: Fri Dec 31, 2010 10:42 am
depends on a whole heap of variables like cyl head mods, cam choice, inlet design/shape & exhaust system but still you can try
DZ
BQ
#6
etc etc etc
PostPosted: Fri Dec 31, 2010 12:12 pm
does ABB / AB8?? sound familiar to n e one?
Rover BBQ..... ;)
PostPosted: Fri Dec 31, 2010 1:07 pm
ok, yeah that`s the later "Bias" (Swinging) needle type , commonly called "Self-centering"
the needles i`ve listed would only be "starter" needles & depending on how the car reacts to one of those needles you`d then be able to make a discission as to where to go from there
but the later swinging needle type carb you sound like you have, to use the neddles that i`ve suggested , you`d have to buy the "Fixed-needle-adapter" to fit them
PostPosted: Fri Dec 31, 2010 2:16 pm
yeh its the swinging type. Would the abb needle be ok for running?
Rover BBQ..... ;)
