It is currently Mon Jul 28, 2025 6:59 pm
Post new topic Reply to topic  [ 153 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
PostPosted: Sat Jan 01, 2011 6:18 am
MrFail wrote:
MrFail wrote:
So Does that help identify it??
Well I looked on the Wade, Camtech, & Waggott sites (the latter had no cam numbers at all) and no joy. 402 doesn't ring a bell to me.
I would go get it reground to a grind that works- then you know wtf it is. :lol:
Oh well. thats a bit of an uninteresting end to that mystery. :lol:
You could set your Cam up in a couple of "V" Blocks, stick a Cam Wheel on one end, and use a dial gauge to tell us all when the valves open, close, and what lift they have at the lobe. Come on, this is a mystery that you can solve for us!!
or not.....
Dicko
PostPosted: Sat Jan 01, 2011 6:45 am
Mods rock!
d1ck0 wrote:
...., and use a dial gauge ......
Sorry here mate, you have to use cam followers, the geometry will be way way out......I check them in an engine block :wink:
PostPosted: Sat Jan 01, 2011 10:55 am
or not.....
Dicko
Haha :lol:
I like that enthusiasm. :D
Well, i have no idea how to measure it, but i would be more than happy to let anyone have a crack at figuring it out if they were keen. 8)
I think its about time i had another dig thru the boxxes again :D
Dusk Blue
1964 850
PostPosted: Sat Jan 01, 2011 2:45 pm
well i found a little container with random screws and other stuff, and guess what else i found.... Something that helps clear the engine size up a little.
and while you're here, i have these little "bad boys" :lol: in amongst the parts.
it seems to have most of the parts. Any ideas on what else would be needed if i was to put these guys on.
The previous owner fitted a brake booster, presumably in anticipation of fitting these disks, but having read a few threads on here the consensus seems to be that it is not really necessary.
If that is the case i would rather remove it and gain the engine bay space back. As I am not too worried about having a firmer brake pedal. My old 72 clubman had un-boosted drums all round and that was fine.
Is there a big difference between un-assisted disks front, drums back and just un-assisted drums all round ???
And if i was to remove it, would i just need to disconnect the brake lines and reconnect them like this??
Thanks
Tim :D
Dusk Blue
1964 850
PostPosted: Sat Jan 01, 2011 2:53 pm
Measure the diameter and thickness of those rotors. Pic is a bit dark but they look like 7" Cooper ones to me, not 7.5" Cooper S.
If so and you are fitting them, I WOULD keep the booster, and fit Greenstuff pads or better.
PostPosted: Sat Jan 01, 2011 3:01 pm
Well you were right ( again :roll: :lol: )
They are 7" , and 4.5mm thick
So are they a worthy upgrade ???? :?
Dusk Blue
1964 850
PostPosted: Sat Jan 01, 2011 3:29 pm
People including Vizard bag out 7" discs, but like any discs they have 1 major advantage over 2LS drums on a road car- they self adjust. 8)
I ran a set for years on my `76 Clubby hydro Minimatic Cooper 998 disc bitsa, they stopped fine with a PBR servo and a set of HF metal king pads. :P
Cooper won their class a couple of years running at Bathurst, so they are not THAT bad. But Cooper S ones are better and more durable.
If ya got em, run em I say.
[edit] post a pic of the pads. If they are the 997 `postage stamps', the calipers can be milled out (by me or others) to take the bigger 998 pads.
PostPosted: Sat Jan 01, 2011 7:42 pm
here it is. :)
Dusk Blue
1964 850
PostPosted: Sat Jan 01, 2011 7:50 pm
OK those are the good later (998) ones.
But fit some decent pads- EBC Greenstuffs, Mintex M1144, etc.
998 pads get hot quicker than S pads do.
Rotors are only 1/4" thick (6.35mm) when new, toss them if under 6mm. Karcraft has new ones available for a bit over $100 each.
A while back, they were around $150+.... :shock:
PostPosted: Sat Jan 01, 2011 7:55 pm
The modern brake pads are vastly superior to anything that was available when all the anti 7" stuff started.
I would be happy with 7" disc brakes on a Mini with modern performance pads.
I would only run a booster if I felt the pedal pressure was too high.
PostPosted: Sat Jan 01, 2011 8:41 pm
ok, so the calipers are good, but the rotors are too worn to be used????
Dusk Blue
1964 850
PostPosted: Sat Jan 01, 2011 9:09 pm
4.5mm TOSS THEM!!!
illegal that thin.
PostPosted: Sat Jan 01, 2011 9:19 pm
4.5mm TOSS THEM!!!
illegal that thin.
Will do.
Thanks again for the help. :D
Dusk Blue
1964 850
PostPosted: Sat Jan 01, 2011 10:19 pm
I don't see any hubs for those brakes??
Sir Alec! we are not worthy!
PostPosted: Sun Jan 02, 2011 7:30 am
You are correct. They are Amongst other necessary parts i do not have.
I figure once i got all that stuff plus new rotors i would be close to the price of a 7.5" setup anyway. So i might keep the drums for now and see what happens.
I might end up giving the 7" brakes a go, just cos they are so unloved.... I do like going for the underdog... :lol: :lol: :lol:
Dusk Blue
1964 850
