It is currently Sun Jul 20, 2025 11:56 pm
PostPosted: Fri Jan 14, 2011 8:40 pm
The thread is stripped on my wiper rack ferrule (the fitting where the wiper motor drive cable joins the wiper motor). I've ordered a new ferrule and it's on it's way. Before I start pulling things apart, just wanted to check how you replace this part. I know how to disengage the cable from the wiper motor, I assume you have to remove the wheel boxes and tubes to get the cable out? :oops:
Thanks for any advice on this.
James
PostPosted: Fri Jan 14, 2011 8:46 pm
Mods rock!
1) Take the wiper arms off.
2) Remover the front cover off the wiper motor (or as Gafmo would put it 'Ripper Motor' :wink: ).
3) Remove the E clip holding the cable to the gear. Remove the cable from the gear, but be careful that you don't loose the little washers.
4) Swing the belden tube up out of the Wipper Motor.
5) Pull the cable out of the belden tube. It most likely won't come easy.
6) Remove the stripped ferral.
7) Install new ferral.
8) Re-assembly is the reverse of the above, although you may have to help the cable back in by turning the wiper spindles.
PostPosted: Fri Jan 14, 2011 8:50 pm
Awesome! Thanks GT :D
PostPosted: Fri Jan 14, 2011 8:55 pm
Good description GT.
I would also add that if you mark the wiper spindles and try to get them the other way up when it is re-assembled they will not be running on the same worn teeth that they have been using for the last 35 to 45 years.
Give the cable a good clean and grease before re-fitting.
PostPosted: Fri Jan 14, 2011 10:52 pm
Also turn the rack cable 180 degrees
PostPosted: Fri Jan 14, 2011 10:59 pm
and hold your tongue just right
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Fri Jan 14, 2011 11:21 pm
Sit beer on air cleaner so it's in easy reach for when you are thirsty.
