It is currently Fri Aug 08, 2025 9:37 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 205, 206, 207, 208, 209, 210, 211 ... 568  Next
PostPosted: Fri Jan 21, 2011 7:03 pm
Stuck some sound deadening up against the internal firewall and behind the dash. Still got to the inside of the bonnet but the difference is huge. Much nicer to drive without so much engine noise or heat. However this has made me notice a squeak in the front suspension. Might be one of the knuckle joints.. Oh well, something else to replace. :)
PostPosted: Fri Jan 21, 2011 8:30 pm
Made the decision whether to get rid of it or keep slowly working on it...Girlfriend said she wants me keep to it, how lucky am I :D
Also started tidying back up the giant mess of mini parts sprawled out in the shed :lol:
 Post subject: Mini
PostPosted: Sat Jan 22, 2011 6:52 am
I gave my mini a good wash and clean.
Classic Not Plastic
PostPosted: Sat Jan 22, 2011 8:45 am
What did you use for the sound deadening may I ask?
PostPosted: Sat Jan 22, 2011 9:18 am
Pulled a disc hub that's going on the Moke to bits yesterday, will lap some new ball joints in today. Realised I used CV's and bearings on another car.
PostPosted: Sat Jan 22, 2011 10:44 am
Not today, but this week, I:
Monday - Started the car and found there was a charging problem. Thought it was the alternator, so pulled it out.
Tuesday - Looked at the car.
Wednesday - Cleaned the engine bay.
Thursday - Picked the alternator up, only to find out that it was ok. I eventually traced the problem to a dodgy wire. Then I put the car back together, jacked it up and checked over all the suspension and steering. Greased my nipples. Washed the car.
Friday - Drove the car down the coast.
Saturday - Drove the car around the hills behind Berry and Kangaroo Valley.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sat Jan 22, 2011 2:29 pm
I went into Clark Rubber and bought some of their foil backed insulation called Formshield. It's 10mm thick (but can be up to 25mm) and weighs next to nothing, but it does the job. Cost was $39.00 per metre. 2m is more than enough to do the firewall and front floor pan or the underside of the Bonnet. I'm just doing the firewall and under the bonnet but will probably end up getting another couple of metres of it to do the rest of the floor pan and boot floor.. I'll get a couple of photos if you want..
I know it's not Dynamat, and not as good, but it's also alot cheaper :)
PostPosted: Sat Jan 22, 2011 2:32 pm
FREAK!!!!!!! :shock: :shock: :shock: :shock: :shock: :shock: :shock:
PostPosted: Sat Jan 22, 2011 4:26 pm
Cut up some scrap to make the front of the rolling jig for the minis, ready for welding tomorrow. The rear will happen next weekend.
Popped out the competition arches from their molds.
I'll take them to work on monday for dressing up, and a sexy paint job................. well primer anyway! :D
mooo, I'm a pig!
PostPosted: Sat Jan 22, 2011 4:33 pm
Machined 4x 40mm Dellorto/Weber stubstacks for Super Cooper. 8)
PostPosted: Sat Jan 22, 2011 10:54 pm
Look Mic, I must say that youd better not put Stilettos and fishnet stockings on em this time, thats not the sort of dressing up they need :shock:
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Sun Jan 23, 2011 7:45 am
latex............. 8)
mooo, I'm a pig!
PostPosted: Sun Jan 23, 2011 8:45 am
Thanks for the info, I'll go and check it out. 8)
PostPosted: Sun Jan 23, 2011 11:06 am
Found the 850 still hiding in the back yard so loaded it up and took it into the house in town and parked it under cover in the carport ready for the spiders to move back in. :) Pumped up the tyres on the "Leyland" mini rust bucket ready to move out to pasture on the daughters block. :cry: Found another house in town to move to with a shed big enough for Project clubby to fit in and work on. :D Contemplated doing some body work but decide i couldn't see with the sweat dripping in my eyes, so came back inside to worship the air-con. :D
PeterN
3x Leylands
1x 850
Mildura,
Victoria.
PostPosted: Sun Jan 23, 2011 1:17 pm
I did finish putting woodgrain dash and rewired the aircon switch for it.
Since light travels faster than sound, people appear bright until you hear them speak
