It is currently Fri Aug 08, 2025 10:31 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 206, 207, 208, 209, 210, 211, 212 ... 568  Next
PostPosted: Sun Jan 23, 2011 1:38 pm
swapped the starter Motor over to a Normal 1 for the time being. Retarded the Timing a little and took her for a couple of runs around the block and shes going much better
PostPosted: Sun Jan 23, 2011 4:13 pm
blew the engine up
PostPosted: Sun Jan 23, 2011 4:50 pm
TheMiniMan wrote:
blew the engine up
Good one? Comprehensively like Minicranks was?.:mrgreen:
Pics or it didn't happen.. :lol:
PostPosted: Sun Jan 23, 2011 4:52 pm
nah, not too big,,, just "Lack-a-lack-a" crank/rod/bearing
oil starvation
easy fixed,,, just add money :-)
PostPosted: Sun Jan 23, 2011 7:47 pm
Maybe a little to much toe in on the front now..but better that the Toe out I had. Adjusted all the brakes again and took Owen for a Drive in Marcia which we got Thumps Up..almost ready for Blue slip
PostPosted: Sun Jan 23, 2011 8:09 pm
NAV-MAN
Removed the cross brace today getting ready to replace the floors. 1 side at a time. Oh why did I start this??
PostPosted: Sun Jan 23, 2011 10:10 pm
So just in case the floor gives out your bum doesn't drag on the ground??
Finished insulating/soundproofing the rest of the car, now I know what it feels like inside a glitter ball.... 8)
PostPosted: Sun Jan 23, 2011 10:14 pm
MiniKit wrote:
8)
You'll need a pair of those.
Nice work on the sound proofing though, looks very neat
How heat/flame retardant is the material though, since its underbonnet?
You're so square
Baby I don't care
PostPosted: Sun Jan 23, 2011 10:35 pm
Buried it in boxes and other random crud
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Sun Jan 23, 2011 10:37 pm
My cousin has used the exact same stuff as insulation and sound deadening under the engine covers for his boat without problem for a while now so I figured if it can survive under those conditions without much airflow then under the bonnet of a mini where there is some, wouldn't be a problem.. But if you like I'll go and torch some. :wink:
Naked flame test results:
In summary I can conclude that by holding a lit match to the foil the rubber backing did melt some but did not ignite. Open flame applied directly to the backing did cause it to ignite but the flames extinguished themselves. I'll try a radiant heat test tomorrow as it's too dark now and my drugs have kicked in....
PostPosted: Sun Jan 23, 2011 11:00 pm
Won't hear any objections from me!
But, pictures or it didnt happen!
You're so square
Baby I don't care
PostPosted: Sun Jan 23, 2011 11:27 pm
You asked for it.......
Please note, no Minis were harmed during this test...
Also please do not try to recreate this at home, I come from a long line of Pyromaniacs and know what I'm doing..
Insulation fire proofing test
Hope this answers your questions.
PostPosted: Mon Jan 24, 2011 7:56 pm
Modified the late model pommie rear seat frame so it will fit into my Aussie 1275LS
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Jan 24, 2011 8:32 pm
Hetty had bit of a flutter/stumble on acceleration from idle so I set about fixing it today. I had been running ATF in the pot and that wasn't working so I tried a couple of different weights of fork oil I had 10w and 15w. They didn't work so I ended up trying engine oil which fixed the problem instantly.. Much more driveable.
PostPosted: Mon Jan 24, 2011 8:35 pm
tacked together the rolling jig for the front of the mini.
Weld it all together properly at work tomorrow.
mooo, I'm a pig!
