It is currently Tue Jul 22, 2025 4:23 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Jan 31, 2011 5:47 pm
There seems to be a trend at the moment of selling or wrecking cars that wont go or are defect.
JEEZ i would have sold some cars over the years.
IT WILL GO just dont give up.
PostPosted: Mon Jan 31, 2011 6:09 pm
Ryan1980 wrote:
tried it simon
it kind of made a popping noise a couple of times from the exhaust manifold (no exhaust yet) before the starter motor stopped.
By the way this is all by spraying aerostart into it, i think the carby isnt set up right (or is rooted)
Well sounds like you're getting closer - retard the ignition more (turn the dissy away from the oil filter) & try again.
If you're worried about fuelling, Morris gave you a clue, after lots of cranking and no running the plugs should be getting wet from all the fuel. If they're dry, more fuel is needed! If the choke is hooked up, try with it on full.
Are the rocker clearances ok? If they're too tight it could explain low cyl pressures...
Jacob
 Post subject: starting prob
PostPosted: Mon Jan 31, 2011 6:16 pm
Hi, sounds like a problem i had had to tow to start would not idle found out it was the choke on carby going back past where the choke should be when pushed into normal position good luck :?:
PostPosted: Mon Jan 31, 2011 6:18 pm
Oh, I forgot to ask, how old is the fuel?
PostPosted: Mon Jan 31, 2011 6:42 pm
hi ryan sent you a pm, give me a call and me and a guru mate will come take a look. no payment, its all for the good of the mini community!
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
i have well and truly ****ed it now. i was trying to turn the dizzy around the other way and it wouldnt go on. I couldnt work out why. I took off the metal plate that goes between the dizzy and the block to have a look and the part inside the engine where the dizzy slides into... has fallen into the engine somewhere.
PostPosted: Mon Jan 31, 2011 6:48 pm
still want us to come?
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Jan 31, 2011 6:50 pm
i really appreciate the offer mate but i can't see the point now... :(
PostPosted: Mon Jan 31, 2011 6:52 pm
i thought you could only get that out if you put a bolt in there screwed it on then it fell in???? sry bro feel you
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Mon Jan 31, 2011 6:53 pm
second opinion...might not be as ****ed as you thought haha
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Jan 31, 2011 6:54 pm
could if have fallen into the sump? maybe i could just take the sump off. Or is it a lost cause?
I dont understand how it could just fall in anyway,
oh well :(
PostPosted: Mon Jan 31, 2011 6:57 pm
This space for rent
oh well :(
This isn't like a normal car, you can't just take the sump off -- that's where the gearbox lives ;) It's an engine-out job, I'm afraid...
yea im prettyb sure thats where it goes......some one may correct me....
1970 mini k
1975 leyland
im sure its fixable, if you want the help me and guru mate can come look tonight, he is waiting to hear from me so let me know. if nothing else you will know exactly what the next plan of attack will be
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Jan 31, 2011 6:59 pm
well apparently its an engine out job, so thats pretty much it really, im not doing that so this car is now for sale.
