It is currently Tue Jul 29, 2025 10:01 pm
PostPosted: Tue Feb 01, 2011 3:42 pm
I'm too much of a virgin in the mini scene to figure this out :oops: so i am wondering firstly what's the diffence with HS2 and HS4 twin su's and secondly what would i need to do to make it run with an 1100(modifications that is) properly or would i be wasting time/money effort and run a 1275 with bore ect ect?
PostPosted: Tue Feb 01, 2011 3:47 pm
Milatsmadmini
HS2 is 1 1/4" carby
HS4 is 1 1/2" carby
on a modded 1100, a hs4 or even a hs6 would be suitable, but hell, if ya got a 1275 lying around, get on it ;)
PostPosted: Tue Feb 01, 2011 4:14 pm
Twin HS2's or preferably a single HS4 on a good manifold is what I would run on an 1100.
PostPosted: Tue Feb 01, 2011 4:26 pm
there`s nothing wrong with twin 1&1/2s on a small bore,,, "IF" you already have them that is
but not sure it`s worth the time. money & effort to go out of your way to get them just because i said they`d be cool... a single 1&1/2 is fine really
if you have a 1275 sitting there looking pretty & if you already have said twin 1&1/2 carbs set up, sitting there looking pretty, then bung them together my friend :-)
PostPosted: Tue Feb 01, 2011 5:23 pm
i wish i had a 1275 lying around just thought id add that in cause the 1100 in it has overheated! probably as a result of driving it around after sitting in an old mans shed for 4 years so next month the whole motor will come out and get a going over/rebuild and thinking which way to go, whether to stick with this motor and modd it(ie twin su's, turbo or supercharge setup) or source a 1275 or just leave it mild pending overall costs considering the 1098 k motor was already in it not the original motor setup of the 998 so the original factor is not an option but as Clarkson says 'More Power'is a good argument
PostPosted: Tue Feb 01, 2011 5:26 pm
How about twin HS4?
PostPosted: Tue Feb 01, 2011 5:27 pm
Is it a daily driver? If it is get it rebuilt stock, maybe a light head job if its cheap.
Then buy a 1275 and build that for a fast road engine. Then slot it in down the track and your laughing.
Simplify and add lightness
PostPosted: Tue Feb 01, 2011 5:33 pm
Good advise considering when it finally gets back on the road she'll be a daily. Just get excited when i have to pull a motor i always think 'maybe i'll just do this and it might go better if i alter it like that'
PostPosted: Tue Feb 01, 2011 6:55 pm
Nothin'n wrong at all with a coupla BIG JUGS..
Go twin HS4's
PostPosted: Tue Feb 01, 2011 7:34 pm
single HS4 on a good manifold will be ample.
PostPosted: Tue Feb 01, 2011 7:43 pm
What I have
Just built a 998 with a 1098 crank nice head, nice Cam & nice exhaust
I have a 1 1/2 on a good inlet manifold that matches with the head & SU. Its goes good
My wifes daily drive is a 1098 with bigger Cam and head has had more work with the Carb matching the head and the exhaust is also a LCB. It has a HIF44 (1 3/4) carb and have never had to touch it.
In say all this you could also go a Dellorto 40 as many do also
PostPosted: Tue Feb 01, 2011 11:03 pm
okay then....what is and does the dellorto 40 do then? webber is it?
 Post subject: 1275 Engines
PostPosted: Wed Feb 02, 2011 5:01 am
Gone are the days when people left 1275 engines lying around... These days they are kept wrapped up in Cotton wool. That is how I keep my stash of them any way !!
"Let us remove your "SHORTS"
PostPosted: Wed Feb 02, 2011 6:23 pm
A 40mm Dellorto is much the same as a 40DCOE Weber.
But they are cheaper to buy s/h, easier to tune (IMO) and are more economical on a road car than a Weber is. Usually. :lol:
Advantages over single or twin SUs-
1. Throttle shafts have ball bearings and seals, so they don't wear and suck air like SUs do.
2. They are basically 2 carbs in 1 body on a common throttle shaft so don't need synchronising like twin SUs do.
3. Easier to tune, as they have real air and fuel jets, not 1 out of 700+ needles to pick.
4. Once jetted right, they stay in tune..... :lol: 8)
5. Better throttle response, once on cam.
Disadvantages-
1. Poorer low speed throttle response. So you just don't treat the throttle like a light switch.
2. Noise/music- they ain't quiet.
3. They do use more fuel than SUs do. But, it's worth it. :P
Here's a Dellorto (45mm) on my 1412 stroker, on GR's engine dyno. A 40mm looks the same.
PostPosted: Wed Feb 02, 2011 6:37 pm
......... easier to tune (IMO) and are more economical on a road car than a Weber is. Usually. :lol:
Doc why is this the case....Japanese manufacturing?
Users browsing this forum: No registered users and 134 guests
