It is currently Sat Aug 02, 2025 9:26 am
PostPosted: Wed Feb 02, 2011 7:07 pm
of the rear Hub Nut on a 76 clubman. It's quite a bit smaller than the front. Is it 7/8ths or 15/16ths? I'm still working through the search on the site but I'll check for replies often until I'm told or I find it.. Thanks guys!
PostPosted: Wed Feb 02, 2011 7:15 pm
Mods rock!
15/16" AF, however a CV Nut from drum brakes will also fit the RH rear. These were 1 1/4" AF.
PostPosted: Wed Feb 02, 2011 7:17 pm
Take a measurement across the flats eg from one side to the other. mm or inches doesn't matter as you can work it out.
25.4mm = 1 inch
Alec
PostPosted: Wed Feb 02, 2011 7:20 pm
Remember the LH rear hub nut is LEFT HAND thread.. but not marked as such.
This one catches heaps of people out... :lol:
Thankyou guys. You rock. :)
It's about 23.4mm so 15/16ths it is. I'm not a fan of using metric spanners on something that may need a bit of force to get off.. I prefer my knuckles with skin on them. :)
Users browsing this forum: Bing [Bot] and 91 guests
