It is currently Sat Aug 09, 2025 4:50 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 212, 213, 214, 215, 216, 217, 218 ... 568  Next
PostPosted: Fri Feb 04, 2011 9:29 am
pulled the 1275 out of the van & pulled the donor motor out of the morris 1100
PostPosted: Fri Feb 04, 2011 9:37 am
Stood around Wednesday night chatting with Lindsay about getting Moneypit finished.
Only been 4 years and the pit ain't full yet :shock:
This year it WILL happen :!:
PostPosted: Fri Feb 04, 2011 2:43 pm
I drove the 1412 down to the muffler place at Seven Hills in the 38C heat, and cadged a bit of 1-1/2" pipe to fix my old Maniflow LCB.
The one I had to use Mr Anglegrinder on to get it off the car! :P
No it didn't overheat, I don't run a cheapo chinese ex-saucepan radiator. 8)
PostPosted: Fri Feb 04, 2011 3:14 pm
what melts 1st? the saucepan or the egg :roll:
what exhaust are you running doc?
PostPosted: Fri Feb 04, 2011 3:22 pm
I had a Maniflow medium bore LCB on the 1310>1360 for around 10 years, then one pipe rusted into the Y piece- so I had to cut the pipe off and grind the remains out. I want to fix it and use it when the 1360 goes back in, it's port matched to the big port head.
1412 stroker in my car now has the same type LCB but newer. It will stay with this motor when it goes into the wife's van.
I used to use Kopr-Kote anti seize on the Y piece joints, it didn't stop it rusting together. I'll use a nickel anti-seize next time (hope it's better for hi temps).
PostPosted: Fri Feb 04, 2011 3:28 pm
I made some new door cards for WLD Monster....MMmmm
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Sat Feb 05, 2011 12:03 pm
Today before the humidity hit I:
Changed the fuel sender float - I now have a working fuel gauge :) The old one was about half full of fuel too...
Also organised my workspace and the goodies I have to go in and on the car starting from next weekend (new gearbox, Maniflow, RC40, intake manifold etc etc etc..). The engine bay is gong to get a nice spruce up in line with the planned theme of the car in the process.
Excited much? Yes
Dave 8)
PostPosted: Sat Feb 05, 2011 12:21 pm
Changed the fuel sender float - I now have a working fuel gauge The old one was about half full of fuel too...
thats a bastard of a job with a leaking float done me brother inlaws the other week but changed the whole sender
the gauge read under half empty before i pulled the sender out and the fuel was more than 10 litres above the sender hole when i pulled it out
WHAT A BLOODY MESS ON A PAINTED CONCREATE FLOOR
PostPosted: Sat Feb 05, 2011 12:26 pm
I understand exactly and could not rely on the gauge knowing that it could be showing me anything. This was my third attempt at doing it, just breaking the seal each time just in case the level was too high. Luckily enough the level today was lower :)
PostPosted: Sat Feb 05, 2011 1:08 pm
PreparIng the body ready for painting, but it's tooooo hot now. :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Feb 05, 2011 5:02 pm
Before it got so hot....I made up my anti-rust mix & started soaking some cooper brake parts & other various rusty items. Once again had to drill screw due to yet another ape destroying the heads :roll: .Will be interesting to see just how well the mix will work :)
PostPosted: Sat Feb 05, 2011 9:15 pm
why didn't you two poke a piece of wire or something in the fuel filler hole to check the level?
PostPosted: Sat Feb 05, 2011 9:30 pm
we did lol
PostPosted: Sat Feb 05, 2011 10:41 pm
I refit my recoed head into the van tonight.
Most of the works done, leaving only the fitment of the exhaust and some minor jobs left to do. :D
Image Image
PostPosted: Sat Feb 05, 2011 11:51 pm
This space for rent
Moved it out of the way so I could get the 'lux near the garage :lol:
