It is currently Thu Aug 14, 2025 4:59 am
PostPosted: Sun Feb 06, 2011 2:39 pm
Hey Guys,
After recent weeks of re-patching up my wiring after a short circuit and oil explosion i've simply had enough. By the time one wire goes from A to B it has changed colour and gauge 3 times...
I need to know what it costs to get a new loom installed and who to go to?
I want this done before OZ50 and i'm located on the northern beaches.
Suggestions?
PostPosted: Sun Feb 06, 2011 2:48 pm
Mods rock!
These guys can do the harness;-
http://www.vinwire.com.au/
Let them know if you need / want any mods as they can do these at the time of makeing yours.
Try Ron Howard Automotive, he's in the Brooky area or Mini's of Sydney, they are in Asquith.
PM sent.
PostPosted: Sun Feb 06, 2011 3:28 pm
I used vinwire, cost me $450 delivered, took a week
You're so square
Baby I don't care
PostPosted: Sun Feb 06, 2011 4:31 pm
Mods rock!
I was just thinking, if yours is a stock harness, why not try Mini King for a good second hand one. Save time, save money. Also chat to him about fitting.
PostPosted: Sun Feb 06, 2011 4:46 pm
Thanks for the help, I'll have a shop around tomorrow
PostPosted: Sun Feb 06, 2011 4:55 pm
Milatsmadmini
+1..... same loom, but i just added a couple more wires (relays for headlights, fuel pump etc)
PostPosted: Sun Feb 06, 2011 7:01 pm
Just another option,
Since my mini will need many many modifications to fit all my modern accsesories, thermo fans, power everything etc Im getting an entirely new loom.
Rocket and ET performance make generic ones ready made usually to go into hot-rods. they work out a bit cheaper than custom modified one form vintage wires etc and come with a complete wiring diagram relays labeled fuse-box and everything else you would find in a new car
PostPosted: Mon Feb 07, 2011 8:11 am
So I can have one here in about a week but I will be fitting it.
Is this something to tackle alone?
PostPosted: Mon Feb 07, 2011 2:09 pm
Mods rock!
If it's just the front harness, not difficult, just fiddley. If you are also doing the rear section, good chance you'll need to tak the roof lining out too.
 Post subject: Tackle it alone ?
PostPosted: Mon Feb 07, 2011 7:23 pm
If you were in Brisbane I would say Bring it to me. I do it all the time... That is what I do for a living repair and re wire Minis and English cars..
"Let us remove your "SHORTS"
PostPosted: Mon Feb 07, 2011 8:04 pm
yes, definitely - putting a wiring loom into a mini may seem daunting, but if it's a proper loom (and should be from vinwire etc.) then everything will be in the right place, and will be the RIGHT COLOUR
get out your scientific publications #64 manual (if you don't have one, get one) and look at the wire colours, and you'll find that if you lay the loom in the engine bay, or on the floor, then compare the colours to the book everything will be in the right and it'll hook right up
it's a really good job to do yourself, very hard to stuff it up
PostPosted: Mon Feb 07, 2011 8:10 pm
Yep give it a Go. I did my own and hid just about all the wires. With a New Loom. Most of the time they label them. Most are easy to work out EG: lights Blinkers, Alt, Horn, wipers. Behind the bash maybe the trickiest but you will nut it out or just ask. Yep Give it a go... which will make yourself proud
PostPosted: Mon Feb 07, 2011 10:21 pm
Its just front and im having it built.. im actually kind of excited :)
Users browsing this forum: No registered users and 277 guests
