watto, here is a copy of the circuit diagram for your moke with a table of items and wire colours. It may help.
now item 5 is the solenoid and there are 3 brown wires ,one to the ign switch [21] second to the light switch[22] third to the alternator[1]
the brown /yellow comes from the ign switch thru the charge light and to the alt.
now if you remove the wires [note where they came from] from the alt, and the light switch and connect the battery with a light globe between the battery terminal and the lead then as you re-connect each wire in turn if there is a short the globe will light up. Just make sure nothing else is turned on.
If it is the wire from the ign switch to the fuses[9&10] there is a wire off the positive side to the coil and then to the dist /points. To test these use the light globe and see if they are going to earth. IE disconnect the wire between the coil and dist and connect the globe with the other side to earth. if this lights the globe then the coil has shorted .do the same with the dist and open and close the points manually.
sorry if it is a clear as mud but best I can do.
to check that it's not the starter jambed in put the car in gear and rock it back and forwards. If it is free and the other parts check out then it could be the starter motor going to earth
www.minisprintgt.com
